Cleaning The Cummins?
Old 03-18-2006 | 04:29 PM
RYANGRAPHITE600's Avatar
Does anyone clean your cummins? Is it neccessary? If so, how do yo go about doing it, and what do you use?
Old 03-18-2006 | 04:40 PM
slimpicken's Avatar
Yes I do it, I don't assume that it is neccesary but I feel a clean engine is a happy engine. the best way would be to just use dish soap and low pressure water sucha as a garden hose and the spray nozzle. I would try to keep the water out of the intake and its not recommended to spray cold water on hot parts but as long as they aren't glowing red I don't think you will hurt anything to much. Have fun it your baby
Old 03-18-2006 | 05:10 PM
Geico266's Avatar
Keep the water away from the electronics, plugs, ect.
Old 03-18-2006 | 06:08 PM
B.Law's Avatar
I usually hose down the engine around 4 times a year with Power Purple and my pressure washer. I've done this on my past 2nd gen and on my present 3rd gen. No issues thus far...
Old 03-18-2006 | 06:13 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Do a search on that issue, I read many differing views on this and even noted that guys with a lot of experience won't even look at a clean one when buying. Possibly some real issues when you clean them if you are not real careful.
Just a heads up on some of the stuff I read
Old 03-18-2006 | 06:38 PM
Pop-Pop's Avatar
If you take the time to get the engine compartment really clean you can then spray everything with armor-all. After that, just use a high pressure air hose to blow off the engine compartment. IMO, this helps keep the rubber & plastic parts in good shape too.
Old 03-18-2006 | 06:42 PM
rammtuff's Avatar
I agree. My engine will never see a hose, unless I have an oil leak that need diag. Wash all that nice grease outa your electrical harnessses and watch the green gremilins go to work.
Old 03-18-2006 | 07:40 PM
Glock Guru's Avatar
"Simple Green" and a garden hose three times a year (every 4 months) and your good to go.
-Troy
Old 03-18-2006 | 07:58 PM
WSA308's Avatar
Don't mean to change the topic but,
How about the inside of the engine, fuel system flush, use 2 stroke oil in fuel tank to clean injectors, etc?
Old 03-18-2006 | 08:23 PM
Willy91's Avatar
Never have washed it and probably never will.
Old 03-19-2006 | 06:14 AM
MikeyB's Avatar
Simple Green and a water hose.
MikeyB
Old 03-19-2006 | 07:34 AM
Glock Guru's Avatar
Thats two for Simple Green
-Troy
Old 03-19-2006 | 09:20 AM
DmaxEter's Avatar
This question gets back to the age old question "why do the fireman wash the truck every time they use it?" Because a clean vehicle is a dependable, efficient vehicle. I always used the pressure washer on my powerchoke and on my cummins to. Never any issues.
Old 03-19-2006 | 09:30 AM
mikmaze's Avatar
no no no no, firehouses round here pretty much have a few kegerators, and if your washing the truck, off duty, the taps are always tippin back and forth..... and as for the armorall use, heck no, I have never seen a product attract so much dust in my life! I think I would try Pledge before armorall....... I have in the past used a two part cleaner / shine for engines. Two seperate cans one ya spray on a warm motor, then hose off, then there was a second can to give it a nice shiny look. can't find that product anymore tho, pep boys used to cary it but no more it seems ???
Old 03-19-2006 | 10:01 AM
edge600's Avatar
You cab mist the engine with silicone spray after it is clean. It will make it shine but doesnt attract dust as bad as Armor All.
Quick Reply: Cleaning The Cummins?
