Check your block heaters...coolant can leak.
Old 01-31-2006 | 12:37 PM
Scotty's Avatar
Top's Younger Twin
All winter long I noticed a very small area of staining on the driveway and finally pin pointed what it is. Even though the coolant level was good...I found that there is coolant seeping out around the block heater at the block.
Spoke with the dealer and he said its quite common. I will see if I can tighten it some and if it stops...great. If not, it gets a new one asap.
Sure glad I found it like this and not with it falling out on the road.
Scotty
Old 02-01-2006 | 08:37 AM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
I had a faulty block heater once on a gasser - it does happen. Eventually the heater shorted out and at -40 it was a tough start after working the night shift. Trouble was it was the middle of winter in northern Ontario (Timmins) and I had to change it in a very cold garage with minimal tools available. Get it changed before you really need it.
Old 02-01-2006 | 04:55 PM
davelinde's Avatar
ditto that. mine was leaking too, very slight.
When I put a wrench on it it seems very loose.
I put it on the list of stuff the dealer will look at next week when I hit 35,500 miles...
ropnjessi
09-12-2007 05:04 PM
nebuniRAM
07-08-2005 08:49 AM
RonP
01-18-2005 06:56 PM
dieselnewbie
29
04-05-2004 08:13 PM
XTOAK
10-27-2003 10:16 AM
Quick Reply: Check your block heaters...coolant can leak.
