Check Engine Light on No Codes?
Old 02-05-2007 | 07:37 PM
msw0567's Avatar
My '06 is 6 months old and has 8,000 miles on it. Last weekend I started the truck and the Check Engine Light stayed on. I drove the truck and everything seemed fine. When I got home I checked for codes using the key on/off method. The odometer went into the display codes mode then flashed done. No codes at all. I took the truck to my friend and we plugged in his snap on Modis scanner. Still no codes. On the way home the CEL went out.
Everything was good for 2 days. Then last night I started it and the CEL stayed on again. Again, no codes. It has been very cold here in MD, around 20 degrees. I do wait for the heater grid light to go out before I start it. Both times the CEL stayed on the block heater was not plugged in.
Any ideas? This is my first Dodge Diesel and I love it. I hope this is not a sign of things to come.
I know the truck is under warranty but if I bring it in with no codes I'm doubt the dealer is going to tell me anything I don't already know.
Old 02-05-2007 | 08:54 PM
xeon's Avatar
I had the same thing. Started truck one morning and CEL light on. Dodge looked at it and could not get codes. They checked everything, looked OK. I disconnected the batterys and CEL has not come on since then...
Old 02-07-2007 | 02:42 PM
msw0567's Avatar
Bump Bump!!
Old 02-08-2007 | 02:25 PM
Fisherguy's Avatar
Good question!
Interesting...
This morning when I started the truck the heater did NOT cycle, I just assumed it was a warm night and cranked her up. After that the check engine light stayed on. I shut it down, turned it on and this time the heater came on. I waited and started it and the check light is still on.
I called and made an appointment for Tuesday, want to have the high idle and accessory delay programmed at the same time.
My question is, what do I do to get these codes you spoke of?
Old 02-08-2007 | 05:41 PM
msw0567's Avatar
I've been told to cycle the key on, off, on, off, on and the DTC will display in the odometer readout. Mine goes into diagnostic mode but there are no codes. Let me know what the dealer tells you.
Old 02-08-2007 | 07:09 PM
Fisherguy's Avatar
Well this is weird, the light was on this moring, stopped on the way and it was still on when I got to work.
After work, started it up, light went out, can only wonder what will happen tomorrow...?
Old 02-09-2007 | 10:56 AM
msw0567's Avatar
Yeah, I know the feeling. Don't want to waste my time going to the dealer for nothing. I'm sure the light would be out by the time I get there.
Old 02-09-2007 | 10:59 AM
Fisherguy's Avatar
My friend has an 04, he says that light will come on if the fuel cap is looseż
Not sure if that's true, but worth checking..?
alltimelow1
04-06-2005 07:28 PM
Jc9995
0
11-29-2004 10:21 AM
Copenhagenjunkie
16
07-25-2003 11:18 PM
Stamey
05-18-2003 10:15 AM
Quick Reply: Check Engine Light on No Codes?
