Charging Problem -- I think ?
Guest
Posts: n/a
I've noticed the last couple of days that when I first start the truck the factory alt gage only shows about 12V, after a minute or 2 it will go up over 14V. Also at night the dash lights will be bright then dim for a few seconds then get bright again. This will last for 5 minutes or so. Don't know if the two are related. Any help will be appreciated. Thanks.
Cummins Guru
Normal when outside air temp is low and engine is cold. Air preheaters are coming on can draw up to 150 amps or more. Its like a toaster oven in your intake manifold. If it is happening after engine is warm then you may have a problem. You might want to have your battery's tested and terminals cleaned at the batterys also. Read this might help.
https://www.dieseltruckresource.com/...d.php?t=121337
Good Luck
Good Luck
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
