Changing 6 Speed Fluid
Changing the fluid on my NV5600. Is there a gasket to replace, or just put on some RTV. I want to pull off the PTO cover (& not just drop the lower bolt) so that I can clean the magnet
You can do either; what ever floats your boat. If you want a gasket, any NAPA carries the standard 6-bolt PTO cover gasket. They may ask you what thickness you want, but in the case of only wanting it for a cover, the thickness isn't important.
I just did mine with redline. Shifts better while moving, but can still be tough to get into 1st when stopped.
I was surprised how much metal was on the magnet (photo in my gallery).
Stock, they are just sealed with RTV. Even with the PTO cover off, a fair amount of oil remains in the bottom, that you could pump out if you want.
jtrimmell
10-12-2007 09:26 PM
Original Junior
05-16-2005 04:04 PM
