Cat Back different material?
Don't know for sure but I'll bet it has to do with the heat generated between the turbo and cat keeps the moisture down so it doesn't corrode as easy. You probably get some condensation buildup downstream of the cat that causes corrosion. Especially if you are not driving the truck far enough or letting it run long enough to dry out the exhaust completely after startup.
Just my opinion.
Dave
Just my opinion.
Dave
I spoke to another guy and he said that he replaced from the cat back twice then went to stainless. From the turbo to the cat it does not aluminized, so not sure if it is different. It is common to just rust out behind the cat?
ramcummins
04-28-2007 10:42 PM
07Dually
03-09-2007 01:25 PM
Jordan5687
33
02-16-2007 01:37 AM
