can the stock injector pump pressure be increased
Old 02-29-2008 | 08:27 AM
goffracing's Avatar
I have an 03 2500 5.9l and was wondering if the pump pressure can be increased on stock pump. trying to run down why my truck hesitates sometimes.
thanks
Old 02-29-2008 | 09:43 AM
bob4x4's Avatar
Yes,there are quite a few pressure boxes to choose from.
Bob
Old 02-29-2008 | 10:06 AM
goffracing's Avatar
is that something that should be done or should i add an aux lift pump first ?
Old 02-29-2008 | 10:18 AM
cgmorgan06's Avatar
You should will out your sig and let everyone know what truck you have and your current mods to it.
Old 02-29-2008 | 11:05 AM
goffracing's Avatar
sorry sig updated
Old 02-29-2008 | 12:00 PM
cgmorgan06's Avatar
edge ez, quad, power puck, mp-8 are all some pressure boxes that could help you out
Old 02-29-2008 | 12:03 PM
03 ant a hemi's Avatar
The stock pump can produce from 0 up to 30,000psi or maybe a little higher not much.
Your stock values will be from 4000 up to 23,500psi.
With a pressure box you should see a max of 26,500psi as the rail pressure safety valve will pop at 27,000psi.
I have had a problem with hard starts I think it maybe the rail pressure sensor.
smokin95's Avatar
I would probably get a lift pump to keep you injection pump happy.
Old 02-29-2008 | 02:05 PM
goffracing's Avatar
do you mean an AUX lift pump thats outside the tank so i will have 2 lift pumps?
forgive my ignorance.
thanks.
Old 02-29-2008 | 02:28 PM
vzdude's Avatar
DTR's 'Go to Guy'
Your pump should be on the back of the filter unless it has been upgraded already by the dealer to the "in tank" version. I'm guessing though, from the original post, that a lift pump won't cure the issues. Neither will increasing the rail pressure. Have yo uchecked codes yet? Turn the key from off to the on position ( not cranking) 3 times ending in the on position. Codes will read off in the odometer screen.
Old 03-01-2008 | 08:05 PM
goffracing's Avatar
ok i have checked and there are no codes at all. and the problem is getting worse at idle it seems like its going to die when i come to a stop and sometimes when backing up slow. this is driving me crazy.
did i make a mistake buying one of these trucks i have never had anything like this with any of my powerstroke trucks.
Old 03-01-2008 | 10:46 PM
vzdude's Avatar
DTR's 'Go to Guy'
Well.......need to get some more info. Do you have any guages? Need to look at lift pump pressure first. Have you changed any of the filters recently? I'd try a new fuel filter if you don't have any access to a guage.
roysleight
08-21-2010 10:01 PM
trik396
04-02-2007 07:16 PM
beandrew
14
11-17-2006 04:10 PM
JimmyLew
34
10-25-2006 05:29 AM
tobyw
07-28-2003 06:55 PM
Quick Reply: can the stock injector pump pressure be increased
