can a dirty IAT Sensor cause mileage to drop???
was wondering if that was possible on these trucks. if the sensor has dirt built up on it, that would likely scew the readings. am I correct?
had anyone cleaned one or have a procedure for doing so?
thanks in advance
thanks in advance
I'm assuming that it's similar to my '05... there's two!
one by the air filter on top of the elbow going down to the turbo. It has 4 wires going to it. Also there is one on top of the intake manifold. This also has 4 wires going to it. This one is near the pressure relief valve & rail pressure sensor.
Both sensor do the same thing. Both are IAT & MAP sensors.
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
If the sensor you're talking about is up near the air filter, that will be a MASS sensor, which meters the amount of air flowing into the motor pre-turbo. It doesn't meter air pressure.
Different sensor all together..............
wow, kinda steered up a lot of different answers. know what I know from messing with EFI cars, i pretty much new the one on the intake was the IAT but I just wanted to confirm
now with all that said, can dirt on that sensor effect the mileage or fuel mixture?
1 Post
If the IAT sensor and or the MAP sensor were dirty, yeah, they could effect mileage. But as stated by johnh, cleaning alone may nothing. If you're in the average already with mpg, cleaning them will NOT give you better mpg. If you see a drastic drop in mileage, dirty sensors might be the culprit. Might just be something else all together.
1 Post
Thaniks. I know mine doesn't, wasn't too sure about common rails. But I was just to state that the IAT and MAP sensors do not do the same thing.
you're absolutely correct that they do not do the same thing. one senses temp, the other senses manifold pressure(boost).
when the engine(coolant) and air(incoming) is cold the electronic units on gassers spray more fuel to help warm up the vehicle faster. if it never senses the warming up of temps, then it will get worse mileage. but I do not know if the CR CTD's do the same thing.
scottboy69358
07-04-2013 02:05 AM
sallyman1
26
08-25-2008 01:22 PM
ArcticWolf
08-16-2005 12:11 AM
