Camber adjustment?
Old 10-14-2007 | 01:49 PM
FastTaco's Avatar
Camber adjustment?
My right front tire is wearing very bad on the outside. Its obvious enough you can tell the wheel is leaning out. Anybody know how to adjust this? I need to try and get it level before it eats a brand new set of tires.
Old 10-14-2007 | 03:56 PM
adventuris's Avatar
have you check yuor ball joints , only way to change camber is to install a set of adjustable upper ball joints
Old 10-14-2007 | 04:26 PM
FastTaco's Avatar
They seem to be fine as far as I can tell. I hear no clunking or popping.
Old 10-14-2007 | 08:01 PM
scootertrash35's Avatar
i was told you have get adjustable camber bolts $30 per side
Old 10-17-2007 | 01:56 PM
bigdreamin's Avatar
Depends if it is 2 or 4 wheel drive. 2 wheel drive you can buy after market eccentric bolts from NAPA. 4 wheel drive you have to shim the ball joint, and it's a PITA. But yes there is adjustment, just not a factory adjustment you can turn like tie rod ends. I would also do a through inspection of the suspension, a truck doesn't just "work" itself out of alignment that bad.
Old 10-17-2007 | 08:31 PM
FastTaco's Avatar
Thanks, maybe it is a ball joint. I need to put it on a lift and check them I guess. Its been like this for a while now and did pull to the right until I got new tires a couple months back.
Mountaineer
12-28-2012 05:01 PM
Racfan9
10-04-2009 06:34 PM
jeff355
09-30-2009 09:39 PM
xp8103
11-08-2004 10:59 AM
Quick Reply: Camber adjustment?
