busted diff bolt
#31
I worked at napa for a minute, never heard of grade ten's ever, sold literally millions of nuts and bolts to oil rigs and they always chose grade 8 bolts and nuts. Grade 8 is stronger than grade 5 but this doesn't mean you should always use Grade 8 they are just stronger, it just depends on what your application is, I would suggest using grade 8's where there areas of high stress like on bumpers and winches and frames, grade 5 should be fine for holding a dif cover. by the way grade 8's have six hash marks on top grade 5's have 3 in a y shape at top. hope that helps.
http://www.boltdepot.com/fastener-in...ade-Chart.aspx
#32
After the 1st front and rear diff. fluid change it is a good idea to toss the original bolts as well as the gasket on the 2nd time around. The bolts are of a soft metal and stretch and have already been done so by the factory once than us for the second time.
The gasket is being compressed so I change that out too.
Don't forget to use the red thread lock on the bolts just below the head when reinstalling or replacing.
Grade 8s are harder than grade 5 and instead of breaking the head off there is a good chance it will strip the threads on the housing first no matter what it does its a PIA eithe getting it out with the easy out than tapping and coiling the hole ( I hear ya Spooler) Grade 5 stretch more than 8s but of course you can only stretch it so far than snap.
Kinda like lug nuts after you stretch the nut a couple of times the nut strips before the stud just a diff. hardness.
afate45
06-07-2014 12:08 AM
FordTrax
04-18-2014 08:47 PM
Jmac
22
06-23-2005 10:55 PM
