bully triple dog & quad boost fooler on 03
i run a triple dog with outlook moniter & was thinking of trying the boost fooler with it.i know i have to ajust my wastgate too how much more boost will the 03 make with this mod & does it work well with the tripledog.
i"ve made this on my 03.... you"ll need a "elbow fooler" and a "boost fooler" the stock 03/04 have around 22/24 lbs of boost!! you should have 32/35 lbs once everything gonna be done... the boost fooler was an necessity on my truck because it throw a "cel" (overboost) i"ve seen a good difference once the mod were made....
i put the elbow on my stock truck and i get more boost with this small mod alone. although the truck will defuel if it gets to high since I dont have a boost fooler
I didn't need the boost fooler!
I have an 03' with the Bully Dog Triple dog and I used an adjustable pneumatic flow control in place of the stock elbow. I adjusted the flow control such that at 20 psi on the inlet, I feel a slight air flow from the outlet. I ran it for a test with the flow control completely closed, and with the outlook monitor hooked up, I did not get any fault codes for overboost. So you may want to try it without the boost fooler first, You may not need one.
If you want, I can look for a part number for the adjustable flow control. It is just a simple industrial in line flow control. The ones on E-bay look like a homemade job. It looked like a standard elbow that someone drilled out and tapped with a setscrew to restrict the flow. Either way the object is just to restrict the flow to the wastegate actuator.
Rough N Ready -
I'd be interested in that part number. I just swapped in a 2005 turbo so I can't use the adjustable boost elbows and since it is no longer electronically controlled it isn't really giving me any more boost. The in line adjuster would be perfect!
cmnsdsl,
I will get you the part number, but it is still just a pneumatic flow control. It will work very similiar to the adjustable boost elbows, just with a finer adjustment. Can you use this with a turbo from an 05 if they are electronically controlled?
Performance & Accessories Bully Dog Triple Dog 40500 w/Crazy Larry, Outlook, boost gauge, pillar mount, boost f
gpshemi
3rd Gen All Products
0
07-19-2015 06:25 PM
rockittboy
11-15-2006 10:05 PM
acook
22
09-23-2006 12:46 PM
RamWheelsBy4
09-17-2005 01:43 PM
JUSTIN1MC
08-12-2005 12:01 PM
