brrrr, cold start this AM, revving @ 1KRPM ?
Old 11-19-2008 | 06:22 PM
98whitelightnin's Avatar
My 03 has it. If its below 32, after 2 mins of idle it bumps up. I have driven down the road 5 or 6 miles and I parked it idling for a few mins and it jumped back up again. I dont know what temp the idle quits kicking in after the truck is warming up.
Old 11-19-2008 | 07:40 PM
Totallyrad's Avatar
Perfectly normal.
Old 11-19-2008 | 10:30 PM
CrashCade's Avatar
Originally Posted by 0524VHO
Is there supposed to be a high idle for 05. I dont think my truck does? just wonderin
Use your triple dog to enable it. There is an option on it that say High Idle.
Old 11-19-2008 | 10:47 PM
no_6_oh_no's Avatar
It doesn't. It will idle up and down constantly when the intake air temp drops below a certain point, even if you are at full coolant temp. ECU's attempt to stop wet stacking and keep the combustion temps up.
Old 11-20-2008 | 09:31 AM
AH64ID's Avatar
It is standard on all trucks, not even a way to turn it off.
its based on coolant temp as well... If the coolant is above 160* it will not fast idle..
~32*F after 2 minutes rpms ramp up to 1,000 (until stopped or coolant reaches 160*F)
~15*F immediately rpms ramp up to 1,000 (until stopped or coolant reaches 160*F)
Old 11-20-2008 | 08:07 PM
moterhead's Avatar
Originally Posted by Raspy
My '04 had to have it enabled. Maybe yours does too. I like it.
The feature that has to be enabled is the manually controlled high idle that is activated/controlled using the cruise control buttons. What is being discussed here is the automatic high idle feature that is activated by cold temps. Don't know when it first became a feature, but my '04 has both.
Redlinear
10-10-2012 08:51 AM
jeepsuck
01-19-2006 03:18 PM
G1625S
12-13-2005 01:40 PM
Korney
13
03-31-2005 11:34 AM
Quick Reply: brrrr, cold start this AM, revving @ 1KRPM ?
