Block heater problems???
I changed the water pump and drive belt this week, and might have killed my block heater. I drained the radiator / motor of coolant completely, then realized after 15 minutes or so that I still had the heater plugged in. So I unplugged it and didn't think much of it. I did the pump and belt later that night and took the truck for a test drive, and all checked out ok. I plugged the truck in when I was done for the night and popped the fuse. I've put in a new heater cord, tried different house circuits, and switched extension cords. It pops the GFI breaker instantly when I plug it in. Did having it plugged in with no coolant short the heater somehow? I don't understand it though, because it wasn't popping the circuit when it was plugged while empty. Is there something else that could be causing this?
So what's the replacement process on these? Are they threaded into the block, or is it a clamp on freeze plug style? I just spend a load of cash on coolant last week, and don't want to loose more than I have to. I want to pull the old one and slam the new on in as quickly as possible so I don't have to replace more fluid than is necessary.
I found the part. The site is cool, in that it gives you diagrams and schematics on parts you are looking for. The problem I have, is that I can't see prices or a way to actually order a part????
rjm022
12-11-2019 09:17 PM
SpeedyWS6
15
02-02-2011 07:22 PM
supersonictoys
11-08-2008 09:17 PM
modiesel
03-07-2008 10:44 AM
