block heater
Old 02-16-2004 | 07:44 AM
Mallard's Avatar
Question block heater
I finally got the cord for my block heater. My question is how warm should the truck temperature guage be upon start up if the truck is plugged in all night ? Last night the truck was in the garage, temperature was about 4 below, when I started it up the temp guage was just off the pin at the 140 minimum temp line. Is that normal ? I have a winter front covering 3 of the 4 grill openings and the truck temperature just made it into the normal range after driving 20 miles to work. IS this normal ? Also the manual says to idle down before shutting the truck off to prevent the turbo from overheating. Is this necessary in winter ?
Old 02-16-2004 | 08:38 AM
Commatoze's Avatar
That's dependent on how long it's plugged it. On a timer, with a few hours each night, you will see little to no needle deflection. However, a few hours on the heater makes a major difference on how long the Wait-To-Start light stays on. I imagine in a protected area, and running all night, you would see a small needle deflection. I typically do 3-4 hours when the temps dip to zero and below.
Old 02-16-2004 | 08:54 AM
rossn2's Avatar
The block heater only heats the water around the cylinders and not the radiator or heater core and is to help start the engine when it's cold outside. You will not see a difference in the water gauge. Mine is on a timer and is on for 4-5 hours. And, yes, it takes a long time for the diesel to come up to normal operating temps..
Turbo Spin/Cool down is for coming off a highway and immediately pulling into a gas station... Just let it idle down for 2-3 minutes. Look in your owners manual, it'll state the procedure. Some guys install a cool-down timer, but they are doing alot of heavy towing.
Old 02-16-2004 | 01:23 PM
Commatoze's Avatar
Here's a thought: If you pulled into the garage in the evening hot, then immediately plugged in, you might have fairly warm water the next morning. But IMO you're only trying to raise the block temp to improve start-ability, and a few hours on the average will do it.
Old 02-19-2004 | 11:54 AM
Eagle Driver's Avatar
thanks spike, I was just about to ask if there was a problem there with plugging it in as soon as I shut down...
Old 02-22-2004 | 12:58 PM
BDude555's Avatar
Not the most reputable source of parts. but, take a look at JC Whitney's web site. you can at least see the MANY different types of block heaters there actually are, you'll be suprised how much more effective some of them are can be.
rjm022
12-11-2019 09:17 PM
SpeedyWS6
15
02-02-2011 07:22 PM
supersonictoys
11-08-2008 09:17 PM
modiesel
03-07-2008 10:44 AM
Reelay
12-01-2005 06:14 PM
Quick Reply: block heater
