Best way to change brake fluid
Old 01-01-2009 | 10:02 AM
freierj's Avatar
What is the best/easiest way to change brake fluid?
Sorry for asking about such an easy procedure.
Old 01-01-2009 | 10:26 AM
badme's Avatar
suck it up with a turkey baster, fill and bleed brakes.
Old 01-01-2009 | 10:28 AM
badme's Avatar
I forgot the most important part. Throw away the wifes turkey baster and get her a new one before she notices it.
Old 01-01-2009 | 11:15 AM
mrblond's Avatar
unplug hoses from the break/steering cooler located between the intercooler and radiator.
Old 01-01-2009 | 01:24 PM
dozer12216's Avatar
This is the simplest and easiest way, especially with anyone to push pedal for you.
Old 01-01-2009 | 02:00 PM
John Faughn's Avatar
Suck out master as stated earlier , then just open bleeders , let drain , but do let master res. empty .
Many yrs. of doing , many yrs. of following extended anti-lock brake procedures , have done this on all kinds , exotic what have you , hasn't caused an issue yet .
The easiest , is have it on lift and step latter to watch & fill res. , it can get involved if you let res. go empty and introduce air , then follow manufactures recommendations .
Do not work peddle while draining , only after all bleeders are closed .
No bottle / catch , being that most brake fluids are water soluble , just flush floor to drain .
Old 01-01-2009 | 09:11 PM
TonyB's Avatar
I've used a pressure bleeder in the past. Actually, I use a 1gallon insecticide / weed sprayer bottle, and buy the motive adapter. Motive adapter for Dodge masters.
Tony
Old 01-01-2009 | 09:35 PM
C Schomer's Avatar
I soldered fittings on an empty 30# freon jug and vacuum bleed with it for the reservoir. I hook clear tygon tubing to the bleeder valves so I can see when the fluid is clean. Craig
Old 01-01-2009 | 10:03 PM
JRRacing's Avatar
Use one of those boat engine oil suckers. I use it for everything from changing jetta oil (fat dipstik tube) to doing brakes. I bleed brakes on every brake maintenence event.
1. suck all old fluid from master cyl with boat sucker
2. fill to top with new unopened or recent known fluid (absorbs moisture)
3. do a brake and bleed with boat sucker hooked to bleed nipple. Do the normal yell to wife and fight over her inability to adapt to the timing. Then get son out and get done in 30 seconds. Pump and bleed til fluid clear and pedal hard. Every brake refill reservoir.
added note. I usually open bleeder when depressing caliper pucks for new pads to see old fluid exit and not push the old fluid into brake line. If nipples bind (not wife) on caliper use teflon tape or neverneize on threads.
Also plan on putting caliper grease on any floating pins. If caliper won't slide on pins pull them out and clean,derust and polish,grease as needed. I carefully wirebrush and apply neverseize or moly caliper lube to metal brake ear surfaces. Not on rotors , or clean with brake cleaner if any grease on them after assembly.
**since I started this there have been no problems with pad wear or squeal (except wife.. she hates when I call her to bleed) on any vehicles in 15 years . Jeep 2002 bleeders were all tough to break loose and got neverseize to get smooth. That boat sucker holds over a gallon and ther is nothing to tip over.
On some rear brake calipers you may need to spin the pucks in (emergency brake system) and not get crazy with the big c-clamp which will destroy the caliper. I bought the spin in kit from napa for 30 bucks or so 10 years ago and find it a pain in the *** but a necessity.
Good luck..
Old 01-02-2009 | 01:20 AM
Fisherguy's Avatar
Anyone else ever broken a bleeder valve trying to loosen them when they're old and covered in rust?
I hate it when that happens...
Old 01-02-2009 | 06:21 AM
freierj's Avatar
All, thanks for your help.
This has been a great site to get information and assistance. Kudos to everybody that participates on this site.
Old 01-02-2009 | 07:24 AM
rjm022's Avatar
http://www.motiveproducts.com/
Old 01-02-2009 | 07:28 AM
MikeyB's Avatar
I use the Motive pressure bleeder. Easy one man job. In fact I did the wife's Magnum a few days ago.
MikeyB
Old 01-02-2009 | 10:18 AM
Ace's Avatar
Ace
Wouldn't that just drain the power steering fluid?
Old 01-02-2009 | 11:59 AM
moorepower's Avatar
I worked on the big brown trucks for 15 years, and all we did is crack the bleeder on each wheel 1 at a time and keep the m/c full, and run until clear. Unless the system is empty, you should never need a power bleeder. To make it a little less mess, take 3 foot of 3/16 id vac hose and push it over the bleeder and run into a jug or pan with floor dry. This will not take 20 minutes. If you feel the need to spend $50 on a bleeder, just send me the $$ and I will send the 3' hose.
Quick Reply: Best way to change brake fluid
