Best T-link steering kit
Old 03-28-2016 | 05:20 PM
Troppy41's Avatar
I would like to change to the T-link steering for my dodge. I have replaced the normal front end components about 3 times in 70K miles so T-link sounds to be beefier and better at preventing wear and the familiar "death wobble" that comes with worn steering components.
Any suggestions for T-link steering kits without breaking the bank?
Old 03-28-2016 | 09:43 PM
BarryG's Avatar
the part number you are looking for is 52122362AL (the AL is the latest and greatest version do not buy a previous version as they recalled more than one of them) you will also need a new steering damper and possibly a new pitman arm. Let your fingers do the looking on the net. I previously found when looking for it quite a range of prices 275 was the lowest and the highest was well over 500. You will find that some of the kits come with a pitman arm and steering damper so make sure to compare apples to apples. Some aftermarket companies are also offering the kits drilled and fitted with zerk fittings
Old 03-29-2016 | 09:34 AM
BILTIT's Avatar
The best without breaking the bank too badly is synergy.
SYNERGY MANUFACTURING :: Dodge RAM Truck :: Synergy 03-13 Dodge Truck Heavy Duty Steering Kit
Old 03-30-2016 | 10:22 AM
ftltmp's Avatar
Originally Posted by BILTIT
I agree with you, I just put this on my truck.
Old 03-30-2016 | 06:09 PM
Diesel Junkie's Avatar
I am on the same hunt.
Need some new linkage, I am at 135kmiles and still on the original stuff.
Synergy looks cool.
Has anyone had experience with the kits from dodgeoffroad.com?
Seems legit.
I also need to figure out how to make my throughshaft damper mount to whatever solution I get.
Old 03-30-2016 | 06:40 PM
ftltmp's Avatar
Synergy looks cool.
Seems legit.
I had looked at those before I bought the synergy, and I talked to a guy in town that runs a 4x4 shop, and I asked him about these, and he said for an everyday driver you dont want the linkages with heim joints,due to dirt and road debris getting in the joints. He said they were more desinged for rock crawlers. He recommended synergy
Old 03-30-2016 | 07:08 PM
Synergy recommends a replacement Mopar Pitman arm.
Does anyone know why?
Old 03-30-2016 | 07:54 PM
Troppy41's Avatar
The users of this site just keep on proving themselves! I appreciate the input guys! Im going to look into the synergy kit!
Old 05-23-2016 | 11:54 AM
crslush's Avatar
I went the Luke's links route and have over 100 thousand miles with no problems. I only had 50 thousand and had a bad joint.
Old 05-23-2016 | 11:58 AM
Late reply,
I went with the Dodge Off Road Full Heim Joint setup.
It is very very nice. Likely indestructible.
Heims are not greasable, so we will see on wear life. But are easily replaceable when they wear.
totalloser
02-22-2013 11:45 AM
jpfishmaster
01-14-2008 08:28 AM
tritont
25
04-11-2007 10:50 AM
Totallyrad
09-11-2006 05:28 AM
ob1kobi
02-17-2005 10:14 PM
Quick Reply: Best T-link steering kit
