Best Oil And Filter?
Old 07-22-2006 | 08:57 PM
nickleinonen's Avatar
fleetguard stratapore & 0w40 xd-3 synthetic for me
Old 07-22-2006 | 08:58 PM
J BODY's Avatar
How about........NEW!
Old 07-22-2006 | 10:11 PM
Col.'s Avatar
Originally Posted by Southern Pride
I use 15w/40 royal purple, and Napa filter. some people talk down rp, but it is one of the cheapest syn oils out there. weve got 2 7.3's fords with over 300,000 on each one. both pull 6,000 lb gooseneck, and 14000lb ford 555c, and the other one a 13500 case 580k almost on a daily basis, between hauling cows and horses around. all of our equipment, boats, etc. have it . i pulled my tranny cover off at 140000 on my old powerstroke. had been running rp atf in it for 80000, it had almost no clutch dust, and no metal shavings. when i wasnt pulling 20000, i was blowing smoke in little rice burners windows!
semper
I Do Agree with You On The RP Oil ,Have You Tried The Long Rider Made by RP ! Its Is The Best Oil Out There ! Ck The Oil Out on There web , Have Buddy Use it In There Big Rigs ,They Say Some Great Things about It .
Regards,
Col.
Old 07-22-2006 | 11:19 PM
jtb51b's Avatar
I personally use Baldwin Filters and Valvoline PB works for me.
Jason
Old 07-23-2006 | 07:23 AM
DirtEater's Avatar
Broke her in with Delo, then switched to Royal Purple 15W40 at 20,000 miles and use the Stratapore filter too.
Old 07-23-2006 | 08:12 AM
chestervip's Avatar
I use Mopar filters (only because I bought a case cheap on ebay) and valvoline premium blue. But I really don’t think it maters as long as I stay within Cummins specifications. I just don’t see the need to spend a lot of money on synthetic oil and expensive filters. I would still expect my engine to out-last my truck.
Old 07-23-2006 | 05:27 PM
1sttruck's Avatar
I use Fleetguard filters and currently am using 50% Delvac 15W40 and 50% Mobil 1 Truuck & SUV 5W40 (basically Delvac 1). I noticed that Exxon XD3 Elite, a synthetic blend, was a bit quieter than Delvac 15W40, and when it became unavailable I started using my own blend. It'll also provide a bit better cold start performance. I like a bit more wear performance, which I assume that Delvac 1 will provide, as the truck see lots of cold starts and also idling in traffic.
Old 07-23-2006 | 08:08 PM
gsbrockman's Avatar
Rotella-T & Fleetguard.....................
Fleetguard # LF16035's and 15W40 Rotella-T until 21k every 5k miles; now I run 5W40 Rotella-T every 8k miles along with a fuel filter change every oil change, too.
Greg
Old 07-23-2006 | 08:51 PM
coobie's Avatar
Originally Posted by WEATHERBY460
I have searched and just can't find anything....................so tell, me what I should go with?
Broke my motor in on chevron delo 400,switched schaeffer 5w-40 9000,and fleetguard straophore filters.coobie
Old 07-23-2006 | 09:02 PM
XLR8R's Avatar
Originally Posted by Geico266
We should be talking about more important things like taste of water.
... or the taste of light beer!
Old 07-23-2006 | 09:05 PM
12PACK's Avatar
Rotella (6 gallon case for $40) and the Fleetguard filters from Geno's 6/2/1 kit.
Old 07-24-2006 | 04:45 PM
SuperDiesel's Avatar
Amsoil series 3000 5w-30, Donaldson endurance, and a nano synthetic fiber bypass oil filter. Best diesel milage I have seen.
Old 07-24-2006 | 06:03 PM
Bswope's Avatar
What is the part # for the Donaldson Filter? My truck is an 06! What fuel filter to go with also?
Old 07-24-2006 | 09:09 PM
Locomotion's Avatar
Post
I saw a fuel mileage increase and obvious operating temp. decrease when I switched from conventional 15w-40 Rotella to Amsoil 15w-40 full synthetic in my '92 Dodge diesel. I continue to use the Amsoil in my 2004.5 but couldn't make another comparison because of how long it takes for the engines to fully break in. I "only" have 28,000 miles on it. I also used Amsoil filters and get the Donaldson through them now. ELF7349
But Amsoil as a new filter that they say is even better: EaO80 for the Cummins.
EaO oil filter info.
Amsoil info and sources.
Old 07-24-2006 | 09:22 PM
tsmay51's Avatar
Mobil 1 filter and any name brand 15w-40
I use mobil one filters mainly from convenience. There is many good ones out there as with oil. Can't go wrong with fleetguard, wix, napa, baldwin, or mobil 1. As for oil, I have used delvac, rotella, valvoline, and delo. My brother has a 89 ctd with 500k on it. It has been abused and worked very hard here in Texas on a ranch. All it has ever seen is a steady diet of exxon 15w40 and fleetguard filters. I would run the same thing but he buys his oil by bulk and I haven't exxon in the one gallon jugs. As for fleetguards, they are just a pain for me to get unless I order them online. If I was in a cold climate I would use a 5w40 synthetic though. Atleast in the cold part of the yr.
Quick Reply: Best Oil And Filter?
