Best mod ever: new drive shaft
#31
When you tow something with your truck does it shudder on takeoff? If so, it might be the shaft. The first week that I had my truck, I towed a 7k trailer a few miles. On the first takeoff I felt a horrible shudder that made me think I was spinning the wheels. As long as I babied it, the shudder was minimal.
The NV5600 is 2" longer than the G56 so it sticks out farther towards the rear-end which is why the shaft has to be shortened.
If you only have 50K miles you are probably good for now...
#32
Sb Qc
Okay so for us shortbox quadcab guys, is there any advantage to going to this shortened aluminum deal ? Mine is a one piece as of now. Can the steel one just be balanced with new u-joints ? I tow heavy ! Whats the good word ? Advantages ?
#33
To half way answer your question you can balance your old steel driveshaft.
#34
Many of us on here speak of the two piece driveshaft as being worthless... NOT TRUE!!! I cashed mine in with some other scrap steel, approx cash value $5. When was the last time your driveshaft bought you lunch?
#36
So if I read this post correctly, the 1 piece AL driveshaft is factory dodge item. If yes, can someone provide me the Dodge part number for a 2004.5 quad cab long box truck wtih an automatic? I want to check and see what a contact at the local dodge dealer can purchase the unit for.
Thanks
SAS
Thanks
SAS
#37
After so many years of dealing with the shudder and hearing how others solved it by changing the shaft, I decided I had to change it too. What a difference it has made.
#38
That's funny. I put mine in my trash can and the trash company put it in my lawn. They took my trash but left the shaft.
#39
ok so i installed my driveshaft today and boy is it light compared to the 2 pc metal one. overall my truck feels the exact same as it did with the 2pc shaft.
but i like it anyway, the only negative is that the front shaft only penetrated about 4" due to the lift i have on my truck but i already drove on it on bumpy roads and all feels ok. i guess i wont have to replace it somewhere down the road.
#40
I got my 1pc drive shaft on tonite too (from Dog House Diesel) , easy job, about 30 mins for me, heavy sucker the 2 pc was. The rear ujoint at the differential was shot one way, the other way was fine, I can barely move the joint by hand, surprise I made it that long, only had vibe on starting to move, and slowing down about 30mph and less. Had a slight vibe at 65+mph.
100k on the truck now. NO MORE VIBES YIPPPEEEE
#41
Thinking that 4" engagement on the transfer case side is enought I guess. Took her down to the river bottom this afternoon and surprisingly managed to get her off the ground about 10"-12" and suspension was under no load and the shaft didn't come out...BUT it did make a loud popping noise on the front end upon landing. After inspecting everything, I have come to the conclusion that I'm in desperate need of balljoints and nobody has carlis yet.
#42
#43
I understand the frustration expressed by some. But I'd still take a "bad" truck to a specialist before spending that kind of money on an unknown quantity.
https://www.dieseltruckresource.com/...s-t259609.html
#44
All I did was take mine in to a driveshaft shop and have them replace the joints and re-balance. Plenty less than half that $630 + shop charges. Had about 160,000 on truck at that point. Guess I'll do it again at 275,000 or so. I'll still be ahead.
Ultimately it's your truck and you have to do what you feel comfortable with.
Just curious, do you have a take-off shudder, empty or loaded?
#45
One question comes to mind outside of whats already been asked.
Factory Dodge is a two piece right, the steady bearing has a slip yoke at the steady bearing. So by going to a one piece all the slipping now takes place at the output shaft instead of the slip yoke. So, are the long box truck output shafts designed for this to occur? I just looked underneath my long box truck and the shaft forward the steady bearing is tight up to the transfer case and doesn't look like it moves back and forth...
Interested in any comments.
