BD aux lift pump
BD aux lift pump
I need some help with BD aux lift pump. The oil pressure switch for the kit. I can't see the plug in the block on the drivers side near the power steering pump they talk about in the directions. I do see a plug on the passengers side just below and to the rear of the oil filter.Can this plug be used for the oil pressure switch? I have a e-mail into BD but have heard nothing back as of yet
Thanks
2004 Quad SB
Thanks
2004 Quad SB
I'm not sure if you can use the one on the pass. side but the one on the drivers side is there,it's the one I used and it's a bit of a pain to get to,if I remember correctly it's right by the motor mount.
Thanks for the info I will try again to locate it. ALCORR that's is a nice setup you have there. I may have to mount on the passenger side because of room .I installed a Super Cooler in the area in front of the fuel tank.
Thanks
Thanks
It looks easy now that it's done but it wasn't easy finding enough space to mount everything. Getting the filter high enough and out off the frame rail so everything could pass under it. The filter is a Baldwin #BF1212, 4 micron with a water separator. I'm still looking for a 2 micron with water separator if anyone knows the number.
Oh ya, I know I'm not to drill holes in the frame rail.
I also use the best additive all winter, haven't started yet, still using 1 qt. of 2 stroke each tank. Think I better change to my winter blend.
