Ball Joints
Old 10-09-2009 | 06:41 PM
Texan1983's Avatar
i run xrf's also... nice units that are way more affordible. bought direct from xrf, nice guy to deal with. he will find you a distributer or sell you them direct if no one is close.
Old 10-09-2009 | 06:42 PM
Texan1983's Avatar
Originally Posted by Vic Romano
Not because of the wheels and tires, because of the Carli system i put on just prior to getting the tires.
xrf makes off-set upper ball joints to correct this.
Old 10-09-2009 | 07:23 PM
Sniper05's Avatar
What did they run ya, if you don't mind me askin!
Old 10-09-2009 | 09:40 PM
Texan1983's Avatar
56.16 for uppers (each)
55.34 for lowers (each)
$11.98 to ship a set of 4 for my truck and a buddy's at the same time.
Old 10-10-2009 | 12:40 AM
bradler's Avatar
Originally Posted by The Tank
why does everyone talk bad on moog's did both uppers for 120 ish 55k ago so signs of wear and they are greaseable?
more than a few people have gotten lowers that caused binding or poor steering...
unless something is bent your camber should be fine as it is not adjustable on our trucks. so unless something is way off i wouldn't use the adjustable uppers, heard of it leading to more problems....
Old 10-10-2009 | 10:35 AM
Fisherguy's Avatar
So the tire shop that put on my wheels and tires said in order to get perfect alignment specs, i'd need to have eccentric ball joints because of the limit of camber adjustment from factory. Anyone know of a manufacturer of these, besides OEM (Dodge does make them for the truck).
Like he said above, you shouldn't need offset BJ's unless the diff is bent. There is NO camber adjustment from the factory.
Did the guy at the tire shop even check out the alignment or was did he just throw that comment out there?
XRF's and the Dyna Tracs are new on the market, hopefully they hold up...
Old 10-10-2009 | 10:50 AM
FLYH2O's Avatar
Carli's are also new Will.
Old 10-10-2009 | 11:19 AM
Fisherguy's Avatar
lol
Yah but I can't afford dem ones...
firebill1720
20
03-05-2010 09:23 AM
njmaier
15
07-26-2006 07:43 AM
getblown5.9
05-02-2006 10:01 PM
Seeder
02-15-2006 08:15 PM
Dynocon
03-05-2005 06:24 PM
Quick Reply: Ball Joints
