Ball Joints
Old 10-08-2009 | 08:38 PM
Devinraptor's Avatar
Ball Joints
I need new ball joints. Any one have any recommendations. I want a good brand but I'm also on a tight budget. Thanks for the help.
Old 10-08-2009 | 08:41 PM
DirtEater's Avatar
Carli, but they're high dollar.
Old 10-08-2009 | 09:01 PM
FLYH2O's Avatar
XRF are built tuff and easy on the pocket book.
Old 10-08-2009 | 09:02 PM
bradler's Avatar
anything BUT Moog......
check out the dynatracs for a nice halfway price point between the carlis and off the shelf brands. they should be pretty solid...
Old 10-09-2009 | 08:58 AM
Vic Romano's Avatar
So the tire shop that put on my wheels and tires said in order to get perfect alignment specs, i'd need to have eccentric ball joints because of the limit of camber adjustment from factory. Anyone know of a manufacturer of these, besides OEM (Dodge does make them for the truck).
Old 10-09-2009 | 09:30 AM
FLYH2O's Avatar
Sounds a bit strange? Why would your wheels and tires effect the camber adjusment?
Old 10-09-2009 | 09:54 AM
guido's Avatar
I'm in the same predicament. My truck constantly pulls a little to the right and I was told the same thing as you as far as fixing the camber problem.
Old 10-09-2009 | 11:45 AM
hector's Avatar
how much are they compared to say NAPA brand (what ever brand they sell) ?
Old 10-09-2009 | 12:30 PM
Hamilton713's Avatar
Its already been mentioned once but save yourself the trouble and stay far away from the Moogs. The lowers are causing a lot of steering issues and the only way to fix it is by swapping them out. I ended up putting the Carli uppers in and OEM lowers.
Old 10-09-2009 | 12:35 PM
FLYH2O's Avatar
$550.00 a pair!
Old 10-09-2009 | 02:38 PM
15 Digger's Avatar
Dynatrac, set of 4 for price of Carli uppers.
Old 10-09-2009 | 04:28 PM
The Tank's Avatar
why does everyone talk bad on moog's did both uppers for 120 ish 55k ago so signs of wear and they are greaseable?
Old 10-09-2009 | 04:50 PM
Sniper05's Avatar
Where can you the XRF's i have a host of part stores around here, but most carry Moog!
Old 10-09-2009 | 05:56 PM
FLYH2O's Avatar
http://www.xrfchassis.com/
Old 10-09-2009 | 06:36 PM
Vic Romano's Avatar
Not because of the wheels and tires, because of the Carli system i put on just prior to getting the tires.
Quick Reply: Ball Joints
