Ball Joint Replacement
Old 10-16-2006 | 11:12 AM
skindaddy's Avatar
how do you know when they are bad, is it tough for a weekend warrior also
Old 10-19-2006 | 11:21 PM
MR.K's Avatar
Is it possible to add a grease zirk or drill a hole and use a needle grease tip ,then plug the drilled hole with a machine screw so that factory joint would last longer?...
Old 10-20-2006 | 12:40 AM
2500's Avatar
best way to keep grease in your ball joint and tie rod end without zerts is with a needle grease fitting. pierce boot and fill full of molly grease.
usually ball joints and TRE will go darn near forever if kept full of grease.
Old 04-18-2007 | 07:00 PM
Crabjoe's Avatar
Originally Posted by Big Bob
Last month I ordered 2 Moog upper adjustable (K7448) and 2 lower (K7467) balljoints along with 2 Percission (464) front axle u-joints from Rockauto.com, all for under $405 including shipping. I ordered them on Monday and they were delivered on Thursday of that week! Highly recommend Rockauto.com for balljoints and u-joints!
I'm a bit confused here because Rockauto is showing the K7448 as the upper for Dana 60 axles... When did they use a Dana on a 3G Ram??
Old 04-18-2007 | 09:05 PM
Big Bob's Avatar
I went to RockAuto's website and looked under a 04 4x4 3500 and don't see anything about a Dana 60 axle. It list the K7448 for the upper and it's adjustable. You may be looking in the 1500 truck or something. Don't know but the 3500 is right.
Old 04-18-2007 | 09:08 PM
Big Bob's Avatar
I found what you were looking at, it was the 2500 application. The printing for Dana 60 has got to be a misprint by RockAuto.
Old 04-19-2007 | 07:33 AM
Peterbilt's Avatar
I put in Moog greasables. From O'Rielly's uppers are $119 and lowers are $72 each.
Pete
Old 12-15-2007 | 12:01 PM
REF>Lancer's Avatar
Most likely late,I got mine from here,http://www.rockauto.com/dbphp/mak,DO...070,Ball+Joint
72dart
06-19-2012 10:42 PM
Wulzcat
12-19-2009 05:15 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
Quick Reply: Ball Joint Replacement
