Bad vibrations in 4th,5th,6th
Old 02-17-2008 | 05:28 PM
Death Dealer's Avatar
My truck is vibrating badly in 4th, 5th and 6th gears (G56). The vibrations compound with each higher gear, but I get no vibes in 1st through 3rd. The vibrations are most noticeable at 2000rpm and beyond. The vibes are not coming from the engine, it is smooth. The vibrations are likely coming from the driveshaft. I would automatically presume it is the U-joints, but any U-joint trouble I've ever had, has gone CLUNK, but I don't get any noises. What gives?
Old 02-17-2008 | 06:34 PM
Spooler's Avatar
It's a u-joint or the carrier bearing. Drive the truck down the road and come home and park it. Climb under it and feel the u-joints. One of the endcaps will be hot. That is the bad one.
Old 02-17-2008 | 06:56 PM
Are the endcaps going to be noticeably hot, since it is -30 here?
Old 02-17-2008 | 07:30 PM
Any chance that it could simply be a driveshaft weight? If it is a u-joint, are there stronger, greaseable aftermarket versions?
SeanB23
04-16-2010 06:20 AM
strokerace
04-16-2008 04:05 PM
Silver04
08-01-2006 06:18 PM
Mark Hodowanec
10-27-2004 10:37 AM
More Power
01-25-2004 06:44 PM
Quick Reply: Bad vibrations in 4th,5th,6th
