Bad pressure solenoid/transducer.
My 06 has very hard upshifts and downshifts. Also around 25-30 mph it wants to drop back into 2nd gear and stay there until I let off the throttle a little then it shifts back to 3rd. Do I have a bad pressure solenoid or transducer or both? I don't have any fault codes.
Im having the same issue w/ mine. But I did throw fault codes. P0700 and P1762.
P0700 - Transmission Control System
P1762 - Governor Pressure Sensor Offset, Volts To Low Or To High
From what i've gathered I need to replace the governor pressure sensor and the transducer. I guess they go hand in hand like a pair of shoes.
My truck seems to start out in 2nd or 3rd gear, real sluggish and I have to apply alot of fuel just to get moving.
Going to do some calling tomorrow and see what I can find out about these two parts. I don't want to install stock parts if I can get a better aftermarket part.
OEM parts, nobody makes a different transducer yet so OEis the only one:
http://www.transmissionpartsusa.com/...-00053397a.htm
http://www.transmissionpartsusa.com/...-000053396.htm
PATC solenoid:
Found here, search #REC http://www.transmissioncenter.net/dodge.htm
Suncoast solenoid:
Found here: http://www.suncoastconverters.com/do..._products.html
Select Kits & Components
PATC solenoid:
Suncoast solenoid:
upjeeper
01-12-2010 07:11 PM
nvr-enuf
10-15-2009 10:03 PM
wcbcruzer
06-29-2009 04:37 AM
bigfish5
11-17-2008 01:41 PM
KillerBee
12-27-2007 10:45 PM
