BAD NEWS for sallyman, changed injectors today...
Old 02-16-2009 | 08:35 AM
Dwitt0187's Avatar
sallyman call me i had the same issue when i changed injectors one time ill tell you what i did 859-445-1453
danny
Old 02-16-2009 | 08:38 AM
sallyman1's Avatar
was it a valve? i can hear compression gasses escape through exhaust. did u have valve problems to?
Old 02-16-2009 | 08:42 AM
Dwitt0187's Avatar
no. it was a bad connection at the connector tube to injector which is very easy to do. pull the vavle cover and loosen the injector wires and pull one off at a time and see which injector is causing the smoking problem pull that injector and reinstall before spending alot of money on something else.
danny
Old 02-16-2009 | 08:44 AM
sallyman1's Avatar
would it make white smoke? i have so much white smoke that i cant even see 100 feet behind me
Old 02-16-2009 | 09:00 AM
Dwitt0187's Avatar
yeah it could also be a bad new injector i had one come from cummins already stuck open when i put it in. i guess they missed it in the reman center.
Old 02-16-2009 | 09:20 AM
sallyman1's Avatar
ill c. i have a 3rd party warranty that covers up to $2500 per claim. that should be the bulk of the bill if i need valve work or new head. i should maybe upgrade to studs then to? are our head bolts reusable? i know some are some arent.
Old 02-16-2009 | 09:23 AM
Dwitt0187's Avatar
yes they are reusable but i would go back together with studs.
Old 02-16-2009 | 09:38 AM
dozer12216's Avatar
All the valve jobs in the country are not going to fix excesssssssss white smoke on reving or driving. Very rare that seats burn on diesel or valve guide wear is a problem. JMHO of course. AT least do a cyliner compression test of sometype. A dealer can do a balance test with scan tool.
Old 02-16-2009 | 09:42 AM
sallyman1's Avatar
if a valve is burnt/warped/distorted and its not seating right you are telling me it cant make white smoke? if a valve isnt sealing right then you have low compression which doesnt ignite all of the fuel , which the piston squeezes through the exhaust valve thats not sealing and hence you get white raw fuel. i have so much white raw fuel that I could fill my friends garage to a white haze in 30 seconds.
Old 02-16-2009 | 09:43 AM
sallyman1's Avatar
just as a quick thought i opened oil fill cap and theres no air coming through it. thats usually a good sign of NO blowby.
Old 02-16-2009 | 10:12 AM
joesixpack's Avatar
You had all this smoke before you changed injectors right? didn't cure it?
If you don't know what cylinder it is, pull the cover and take one wire off an injector and run it a short while untill you figure out which cylinder it is.
This will throw codes, so a way to reset the cel's (uploader)
(DO NOT TOUCH THESE WIRES WHEN RUNNING) (100V peak can be shocky)
Then pull that injector and blow down the hole with a rubber tiped blow nozzle, you'll find out quick if its a valve.
Then you know what your looking at, head job - motor job.
Burnt valves on these arn't nearly as common as burnt pistons/rings
Old 02-16-2009 | 11:36 AM
sallyman1's Avatar
truck isnt by me now. its 30 miles away.i have a 3rd party warranty that will do $2500 per claim. i might as well let someone else worry about it now.
Old 02-16-2009 | 11:37 AM
sallyman1's Avatar
do our trucks have liners or just a bore in the block itself? maybe if its piston/rings would it pay to do 1 only? or do al 6? thy could change the liner maybe if its wet or dry liner?
Old 02-16-2009 | 12:50 PM
han solo's Avatar
No liners, have to jump to the 8.3L to get wet liners.
Old 02-16-2009 | 02:00 PM
sallyman1's Avatar
the only thing i wanna know is it possible to be able to hone in frame on cylinders 5 and 6....could a person even do our trucks in frame. ive done semi trucks in frame but our might be a little tougher
Quick Reply: BAD NEWS for sallyman, changed injectors today...
