Axle seal leak... No new pads
When I was installing a fifth wheel hitch I noticed the right wheel had grease all over the inside and all over the tire...The dealer replaced the axle seal and I asked them to check the brake pads (probable coated w/ oil)
They said they used brake clean...I suspect just on the rotor . I will be towing an 11000 lb camper and don't want any brake issues. What do you guys think???
Thanks,
Jim
Thanks,
Jim
Brake clean alone WILL NOT get the oil out of the pads at all. Likewise the top layer of the rotor will still be contaminated. Cast iron is slightly porous and any oil or grease will get trapped in the top layer...the only solution is to machine the rotors and replace the pads.
Originally Posted by J BODY
Grease was most likely slung behind the area where the caliper is. I don't think you'll have any probs. Hard call to make without seeing it in person.
Chip
14
06-21-2009 03:59 AM
dieseljerk
07-08-2004 07:23 AM
