aux fuel tank kit install
Old 06-20-2008, 05:19 PM
grey ghost's Avatar
I just purchased a 100 gal better built tank, has any one had problems with the check valve at the fill hose sticking open and over filling?
Old 06-20-2008, 09:18 PM
Ramyes's Avatar
There must be a vent on top of the stock tank. If I leave mine open and it sits for a day or so I get a small drip from the stock tank.
Old 06-21-2008, 05:34 PM
grey ghost's Avatar
thanks ram yes, whent to mexico today to get fuel, all out ,from TJ all the way to el golfo
Old 06-21-2008, 07:43 PM
FiverBob's Avatar
I have never had mine not shut off, but I usually stick close by it - - I don't want it all the way full. I stop about three gallons short of full to prevent slopping out the vent. But, the fill will shut off without a problem.
Old 06-22-2008, 10:15 PM
shortbed rv's Avatar
Hi Ramyes,
I am assuming that you have an aux tank and if you leave the gravity feed open for a day or two the stock tank will start to leak. This happen to me once( after two years of leaving the valve open) but I could not find were the leaking was coming from. Maybe the canister gasket or perhaps out the vent. Could you locate your leak?
Now days I have just been leaving the manual valve closed and open the valve when needed.
Very small leak.
Old 06-25-2008, 03:35 PM
Minwy's Avatar
Its best to use a shut off valve, mine leaked all the time. Most aux tanks will hold pressure, usually around 2psi, then a little bit more pressure from gravity and you have the factory tank constantly overfull with pressure on it to boot. The rollover valves dont take much to leak, at least mine didnt. I am using a solenoid valve on mine so I just have to flip a switch to fill the tank.
Doc12
03-06-2016 10:51 AM
CODODGE2500MAN
08-11-2009 04:13 PM
PRO-NRA
16
04-01-2008 12:13 PM
ramsport59
MDDTR #33
02-21-2008 04:15 PM
blakedill
12-04-2005 12:59 PM
Quick Reply: aux fuel tank kit install
