Auto or 6 speed ???
Old 07-14-2006 | 03:21 PM
XLR8R's Avatar
Originally Posted by Michael1
There is no law that says you have to go through every gear when accelerating or decelerating (unless you are after the big rig sound). I skip gears all the time. That's the advantage of the manual. You only use the gears you need at the time.
Michael
Yeah!
I'm a driver & love all the gears... still can't find 7th!!!
Gotta love that big rig sound with the super BHAF & custom SS exhaust.
Old 07-14-2006 | 04:22 PM
Marine's Avatar
I have a high performance auto now, but my new truck is a 6 spd. I like the auto for faster pick up, but I would rather have the control of the 6 spd.
Old 07-14-2006 | 06:19 PM
Flashman's Avatar
Throw some taller tires on the six speed and you drop your RPM, also looks better and gives more ground clearance.
Old 07-14-2006 | 07:40 PM
Marine's Avatar
This is what I will do when the stock set wears out.
Old 08-20-2006 | 08:39 PM
gdahlbeck's Avatar
question
Originally Posted by ramtd02
my 6 speed is getting around 20, that is at 70 mph and 2150 rpm...i will be getting a gear vendors unit in a couple of months, that'll drop the rpms to about 1500, so it should get better mileage
What is a gear vendors unit? Thanks
Old 08-20-2006 | 08:41 PM
Marine's Avatar
It is like a rear end splitter, I believe.
Old 08-21-2006 | 09:37 AM
mule3010's Avatar
It seems as if the 48re has solved almost all the reliability problems that were around in the past. Look around here and see how many 48re's have had to be rebuilt/replaced,I would bet not many more than the six speeds. So if the reliability is as good,it is faster,is rated to tow more,gets better milage and you can go through a stop sign without multiple shifts, what's so bad about it.
Joe
Old 08-21-2006 | 09:54 AM
gdahlbeck's Avatar
Taller Tires
How much taller tires can you go with without having clearance problems and how much of a difference in RPM will it make at 75 MPH?
Old 08-21-2006 | 10:26 AM
CSAGrey1's Avatar
Manual will always get my vote.
Old 08-21-2006 | 08:09 PM
kev94mx's Avatar
Look at my post on my 06 auto. I dont know what I am going to do.
Old 09-01-2006 | 10:12 AM
HONDA99's Avatar
manuals my vote so much more fun when you need to smoke somone out or you want to make some noise
Old 09-01-2006 | 09:29 PM
FATCAT's Avatar
If you want an automatic transmission, buy a Crown Vic. If you want to buy a truck then there is only one choice ... but the G56 tranny in the Dodges is just barly a truck transmission.
Old 09-03-2006 | 12:27 AM
JohnInNH's Avatar
6 speed with 3:73's will get about 5 mpg less on the highway at 75 mph than on the back roads at 55 mph in 6th. It's all due to the low gearing.
I'm ordering a gear vendors overdrive unit Tuesday. 22% overdrive. It will give me about 20 MPG I like to drive at 75 MPH. the 6 speed is spinning kinda fast; about 2300-2400 RPM at that speed. it will drop to 1800-1870 rpm for the same speed. That's perfect. I bet I will break 20 MPG after the truck is broken in.
At $3.25 a gallon it will pay for it's self in a few years, but more importantly the motor will spin less RPM per mile. That is good. It is also in the right RPM range for power/torque. It will be more fun to drive.
It's easy to install. I plan on taking it from truck to truck when this one goes from the salt.
It will also let you go a lot faster if that is something you are into. Out in the flats of the big states you will get rear ended if you only go 70 MPH.
All I need to do is cut a little less than 14" of my drive shaft and bolt it in. A few wires and I'm good to go.
Tires will be cheeper... It will be a nice sleeper. Not many 18 speeds out there. (6 low range and 12 high range) I should find the right gear for any MPH. No excuse for lacking the correct ratio.
I think it will be good for 100 MPH too
No to only find the correct Bilstein shocks for the 2006 4x4. I think it's BE5-6681 front and BE5-6647 rear. Geno's says the rear is BE5-6682
The stock shocks are garbage!
If you tow a lot of weight keep in mind with the G56 that direct drive is 5th gear. So on hills you should use 5th in OD and spare your 6th gear from potential damage. The Gear Vendors unit is good for 35,000 lbs IIRC. So it;s made to take the weight.
I can't WAIT!
Old 09-03-2006 | 07:24 AM
gdahlbeck's Avatar
Gear Vendor's and Warranty
Will installing a Gear Vendor's unit void the drive train warranty?
Old 09-04-2006 | 11:19 AM
Hairtrigger's Avatar
I drove a six speed for 150 miles before buying an auto.
I spend a fair amount of time in my truck and being in sales I am on the phone quite a bit while driving.
Quick Reply: Auto or 6 speed ???
