Auto or 6 speed ???
Auto or 6 speed ???
My first gen is in the body shop and MAY get totaled. If it does I'll be buying a new truck. Has Dodge fixed the auto trans so that the diesel doesn't eat it up? My first gen (92) had the tranny rebuilt twice by Dodge under warranty and then again out of warranty. If the Turbo diesel still beats the tranny up, I'm inclined to go with the six speed. If I can find one here in So Cal.
I tow a 30ft toy-hauler when I tow. Weight around 6-7,000lbs. Too much for an auto?
My son is a salesman at a local Dodge dealer so finding exactly what I want, as soon as I know what I want, shouldn't be a problem.
If you want to go fast and rebuild the auto then get the auto, if you are more interested in pulling and highway driving then get the 6. In my opinion the only reasons to get the auto is if you want to race and if you drive around town alot auto is easier.
Originally Posted by packard8
Taller OD ratio on the auto.
Originally Posted by supersonictoys
and thats the only reason? I wonder if you could order 3:54 gears for these rear ends?? anyone ever looked into it? not saying from dodge but from a differential place.
so different gears arent an option for better mileage unless you have the 4;10's and bigger tires and wheels are around $5000!! , so has anyone tried a gear vendor overdrive and if so was there a mileage increase?
Originally Posted by Mike S.
My first gen is in the body shop and MAY get totaled. If it does I'll be buying a new truck. Has Dodge fixed the auto trans so that the diesel doesn't eat it up? My first gen (92) had the tranny rebuilt twice by Dodge under warranty and then again out of warranty. If the Turbo diesel still beats the tranny up, I'm inclined to go with the six speed. If I can find one here in So Cal.at
Michael
I to own both an auto and a 6 speed and my only 2 beefs with the stick are that the gears are so close together(meaning that you spend all your time shifting) and that the rpm's are quite a bit higher on the highway. my auto is smooth as glass and I notice NO vibration of any kind. the auto is also showing 22 on the overhead and actually getting 20.5 on the highway at 65. the 6 speed gets around 15 under the same conditions but has only 5 k miles. I strongly suggest you drive both before you buy or you may regret it.
my 6 speed is getting around 20, that is at 70 mph and 2150 rpm...i will be getting a gear vendors unit in a couple of months, that'll drop the rpms to about 1500, so it should get better mileage
I to own both an auto and a 6 speed and my only 2 beefs with the stick are that the gears are so close together(meaning that you spend all your time shifting) (
Michael
