Aoto Trans Hot Line Temp Probe - Help
Old 08-15-2007, 03:07 PM
welndmn's Avatar
Does anyone remember the McMaster Carr Part numbers?
I ended up with the Mass Diesel line, but had the McMaster part, but lost it....................
Wanted another for a friends truck.
Old 08-15-2007, 03:09 PM
welndmn's Avatar
Found it
added to this post in case I loose it again...............
5929K146
22$
Old 08-15-2007, 05:03 PM
torkmnstr's Avatar
I second the diesel manor line, it was a breeze! I think I had done in about 30 min, definitly worth the money!
Old 08-15-2007, 06:17 PM
TonyB's Avatar
Originally Posted by soulezoo
It drives me crazy watching the temp hit 220 while just idling at the light. I'm thinking sometimes ignorance is bliss...
It's common for mine to hit 210 sitting in traffic at a light...Even with the Mag-Hytec pan on. However, I do notice faster cool down with the Mag-Hytec pan, though. It used to take ~1mi (next stop light) to get back to ~180. Now it takes ~1/2mile.
Oh, and we usually hit 100-115 in the summers, here in Lovely Phoenix.
Tony
Old 08-15-2007, 07:22 PM
chucktuna's Avatar
I went the cheap route and went to the local ACE Hardware store and after trying all the fittings with my cut line and temp probe I finally cobbled it all together. Looks just like what Diesel manor sells.
I was worried that it may leak or blow apart, but after 6k, no problems.
Wish I had a picture for you.
and yea, mine runs 200 plus at the hot line.
TC lock up switch helps keep the temps down.
chuck
Old 08-16-2007, 10:40 AM
TonyB's Avatar
TC lock up switch helps keep the temps down. chuck
Where's you get the wiring details for the lockup switch on the '06?
Tony
Old 08-16-2007, 10:51 AM
jrussell's Avatar
Tony
Here ya go...
https://www.dieseltruckresource.com/...ght=definitive
It's a really long thread and not specific to 06's, but the 06 info is in there somewhere.
Old 08-16-2007, 12:55 PM
DTR 1st Sergeant
soulezoo's Avatar
Tony
I do have a tight converter from Goerend and when idling the temp goes up really fast. However, as soon as the TC is locked whether by switch or on its own the temp goes right down just as fast. Cruising on freeway in 100* weather is 170-180.
Old 08-16-2007, 04:46 PM
TonyB's Avatar
With the mag hytec pan, I can usually get down to ~170, so long as the ambient temp is below 100F. If it's >105, 180F is as low as it will go!
Agreed, TC lockup keeps the trans MUCH cooler...less slip!
Tony
Old 08-16-2007, 05:38 PM
jrussell's Avatar
Mine seems to run a little cooler than that unloaded on the highway. It runs 150-160* in 80* temps and 160-165* in 100* temps. This is at 70-80mph.
RoadDiesel
06-16-2007 09:24 PM
Lrdchaos
06-30-2005 07:23 PM
2500TurboDodge
08-10-2004 10:06 PM
Reelay
05-06-2004 07:29 AM
kibbleking
10-02-2003 01:36 PM
Quick Reply: Aoto Trans Hot Line Temp Probe - Help
