anything i should do....
Old 12-10-2008 | 09:25 PM
billie's Avatar
Keep in mind that you have a heavy truck that will break loose in snow and ice easier. Don't hesitate to use your 4wd if the roads are slippery. Have a good trip.
Cya
Old 12-10-2008 | 09:27 PM
billie's Avatar
Oh, and don't forget to lighten up your trailer brakes on icy roads.
Cya
Old 12-10-2008 | 09:31 PM
txfiremedic's Avatar
Aggie Girl, don't waste your money on Anti-gel, its not cold enough to need anti gel around here. I always add Power Service Diesel Gray bottle with every fill up, it helps lubricate, but you don't need an anti-gel.
Old 12-10-2008 | 10:16 PM
dslpwr81's Avatar
Use the white bottle. It is an anti gel, PLUS a lubricity adder. No point in using the grey bottle when the white is the SAME thing, but with anti gel in it. You never know. Weather can change. For instance, today in Montana it was around 35 degrees. On Sunday, our high is suppose to be -6. Be prepared. Use the white. I'm not disagreeing with you TXfiremedic, just tring to prepare her. The bottles are the same price.
Old 12-10-2008 | 10:25 PM
aggiedieselgirl's Avatar
Talking
oh wow lots of tips thanks so much guys yall are wonderful!! this will be the first time i have made this trip towing something alone so its gonna be a change!! i will keep in mind all of what yall said!
Old 12-11-2008 | 12:17 PM
DBLR's Avatar
IIRC unless the temps will be colder then zero you should not need to use more then 16oz of the white bottle power service per 34 gallons of fuel. After the first does you will only need around 10 oz per 25 gallons.
lifer
05-09-2006 05:42 PM
Hoss
16
11-12-2004 04:19 PM
2manykids
07-27-2004 12:48 PM
gullydog
03-21-2004 01:19 PM
dcwm
12-07-2003 07:06 PM
Quick Reply: anything i should do....
