Anyone running Lucus and powerservice?
Old 10-24-2007, 12:11 PM
  #31
DBLR's Avatar
Mopar1973man,
Why should I use 2-cycle oil if I have problems from it every time I use it? BTW, I don’t use Lucas in every tank, but is sure does clean up my injectors after burning 2-cycle oil. Like I’ve said before if it works in your truck good for you, but 2 cycle oil does not work well for everyone for some strange reason.
Old 10-24-2007, 01:12 PM
  #32
Mopar1973man's Avatar
Maybe you should read up on the chemicals in diesel fuel...
http://www.cpchem.com/enu/msds_unsec...NGLISH_A_N.pdf
There is a lot of solvents in diesel fuel...
PM coming at you...
Old 10-24-2007, 01:59 PM
  #33
DBLR's Avatar
After seeing what Chevron mixes in their diesel I've requested a MSDS from: http://www.premiumdiesel.com/product/arctic.aspx This is the company that makes the fuel I use in the wintertime. It cost a bit more but I get better mileage from it then the normal 70% #2 and 30% #1 diesel mix most use around N. IA in the wintertime.
Being I've not found a good additive to use that my truck likes I try to burn a tank once a month of Performance Gold diesel from Flint Hills, that is when its not 24 cents a gallon higher then what Murphy oil sells.
Old 10-24-2007, 02:45 PM
  #34
Roperteacher's Avatar
I should have my XPD opti lube MSDS sheets today!!
Old 10-25-2007, 10:51 AM
  #35
DBLR's Avatar
If you do use the XPD opti make sure you let everyone know if its any good or not.
gerry
08-27-2005 07:18 AM
Jmac
18
01-21-2005 08:22 PM
Jmac
12-19-2004 10:05 AM
Gear Poet
07-02-2004 09:32 AM
KATOOM
17
04-12-2004 09:02 PM
Quick Reply: Anyone running Lucus and powerservice?
