Anybody owned both a G56 and 48RE?
Old 12-14-2009 | 12:41 PM
00Dog's Avatar
Just curious if you noticed a lot more noise and clatter on shutdown with the G56. I can't tell if something is loose or it is just transmission or higher idle speed related. I'm going to the dealer tomorrow for tire size calibration and was going to ask them but they always say everything is normal.
Old 12-14-2009 | 02:30 PM
cbrahs's Avatar
push in the clutch on shut down and it won't do that anymore. plus it is easier on the tranny
Old 12-14-2009 | 06:00 PM
00Dog's Avatar
It is better with the clutch in but still way more racket than the 06 auto.
Old 12-14-2009 | 06:59 PM
p035970's Avatar
It's normal. Mine 2007 and 2001 both have always done it. Jay
Old 12-14-2009 | 07:40 PM
Dodgezilla's Avatar
Yeah, it's normal.On the 07 G56 truck I used to have I ended up just pushing the clutch in when I shut down and it helped a lot....
Old 12-15-2009 | 05:39 AM
ColdCase's Avatar
I think it has something to do with the combination of the dual mass flywheel and tranny input shaft. Mine has always clattered.
Old 12-15-2009 | 07:00 AM
slorocco's Avatar
I've found that with the clutch pedal pushed down and the tranny in gear is where I get the least noise and clatter on shut down.
Old 12-15-2009 | 05:37 PM
FSTDL's Avatar
I think the auto having a bit of a load from the transmission front pump must dampen the shaking a bit.Yes the manual does shake a bit more.
osci
09-16-2008 02:26 AM
Bersaglieri
07-24-2007 07:56 AM
fordtillidie
11-16-2004 10:01 PM
barracuda
01-27-2003 08:34 AM
Quick Reply: Anybody owned both a G56 and 48RE?
