Antifreeze
Old 01-11-2011 | 12:52 PM
Bob 1's Avatar
Antifreeze
On the overflow tank i noticed my antifreeze is pinkish and the tank says don`t use normal antifreeze.
Is this true? Does the motor require a special antifreeze?
Old 01-11-2011 | 01:30 PM
madhat's Avatar
Administrator/Jarhead
Yes. It requires a HOAT (hybrid organic something or other).
You can get it from dodge, or there is a commercial antifreeze that meets the requiremenrs.
Old 01-11-2011 | 01:54 PM
nofatum's Avatar
TURBO DIESEL REGISTER
1150 Samples Industrial Drive
Cumming, GA 30041
(770) 844-8877
www.turbodieselregister.com
TECHNICAL TOPICS
ANTIFREEZE FOR YOUR TRUCK
by Robert Patton, TDR Writer
In this issue we’re going to cover another subject that causes confusion among the TDR faithful (although nowhere near the emotional reaction as our recent lube oil articles in Issues 54-58): the correct antifreeze for your truck. Issue 54’s article by Andy Redmond gave you the Chrysler and ASTM specifications that you should use in your purchase decision. Yet, with the wide choice of products at the auto parts store, it puzzles the mind. How so?
In looking for a way to introduce the subject there were many titles that were considered: the straightforward, “Read Your Owner’s Manual”; the condescending, “Your Perception is Reality”; the jovial, “Antifreeze and You”; the serious, “The Need for Coolant Additives”; the interactive, “A Coolant/Antifreeze Pop Quiz”; and the technical, “Specification Numbers and Antifreeze.”
The decision—let’s do, “13 Questions About Your Cooling System.” The article covers more than just antifreeze, so read on.
Q1: I’ve often heard the term “cavitation erosion” in the same sentence as diesel engine. What is cavitation erosion?
A1 With a term like “cavitation erosion,” you might think those affected would be found in the waiting room at your dentist’s office. Not so. Cavitation erosion or liner pitting, if left unchecked, is a real issue with some diesel engines. Okay, I guess there is a parallel to your dental hygiene. A cavity is a cavity, and both types can drain money from your wallet.
To further clarify the issue, you may have noted that the cavitation erosion is an issue with some diesel engines. Which ones? All diesel engines with wet sleeves are subject to cavitation erosion or liner pitting if the cooling system is not properly maintained. The wet sleeve design means the cylinder liner can be removed and replaced in the block. Although the cylinder liners are pressed into the block, wet cylinder liner design does not have the same structural rigidity as a cast block design.Under-concentration of coolant treatment additives will result in liner pitting and engine failure.
The Cummins B5.9 and 6.7 liter engines are a cast block design and do not have wet or removable sleeves.
To add further explanation to the liner pitting phenomenon, I’ll quote from a Cummins Inc. Cooling System brochure. “Liner pitting is caused by vapor bubbles formed when the piston strikes the liner during engine operation. The energy generated during the combustion process and the side-to-side motion of the piston causes the liner to vibrate at a very high frequency. The liner moves away from the coolant fast enough to form vapor bubbles.
“The vapor bubbles collapse against the liner surface as the liner moves back into the coolant. The implosion of the vapor bubble against the liner surface produces a very high velocity jet of water. This water jet removes material from the liner surface. The jet of water acts on the liner surface with a pressure exceeding 15,000 psi. This process repeats again and again, resulting in liner pitting.”
Q2: Is cavitation erosion or liner pitting a concern on my Turbo Diesel?
A2: No. Again, the Cummins B5.9 and 6.7 liter engines are a cast block design and liner pitting is not a concern.
Q3: How about my buddies with their Ford and GM diesels? Aren’t both of those engines cast block designs?
A3: Yes, they are. My friends with the GM engine advise that their Owner’s Manual does not mention the need to treat the cooling system with supplemental coolant additives (SCA). However, even though the Ford is a cast block design, the PowerStroke owners must use SCAs to prevent the cavitation erosion problem.
Q4: Okay, I understand that the Cummins B5.9 and 6.7 liter engines do not need supplemental coolant additives. But, I would like to learn more about SCAs so that I can inform some of my Ford friends. Tell me more about SCAs…
A4: How about an easy-to-understand analogy?
Do you wax your vehicles? Just like waxing is necessary for long lasting paint protection, SCAs form a protective coating on the engine’s cylinder liners. Just like wax wears away, the SCAs have to be replenished in the engine’s cooling system. There are easy-to-use test strips (remember high school chemistry?) that tell the owner how often/how much SCA to add to the cooling system.
No. Again, the Cummins B 5.9 and 6.7 liter engines are
Q5: In issue 54 TDR writer Andy Redmond gave us the specifications for coolant. Could you do a reprint?
A5: You bet. Here is the TDR Issue 54, page 157, reprint:
Q6: Since 1989 the coolant type listed is ethylene glycol. How does ethylene glycol (EG) compare with propylene glycol (PG)?
A6: Ethylene glycol and propylene glycol are clear liquids used in antifreeze and deicing solutions. Both are clear, colorless, slightly syrupy liquids at room temperature. Ethylene glycol is odorless, but has a sweet taste. Propylene glycol is practically odorless and tasteless.
Ethylene glycol is toxic. Eating or drinking ethylene glycol can result in death, while small amounts can result in nausea, convulsions, slurred speech, disorientation, and heart and kidney problems. Ethylene glycol affects the body’s chemistry by increasing the amount of acid, resulting in metabolic problems. Similar to ethylene glycol, propylene glycol increases the amount of acid in the body. However, larger amounts of propylene glycol are needed to cause this effect.(1)
Q7: It seems that PG would be, literally, a safer product to use. Why is it not widely accepted?
A7: Ethylene glycol (EG) has been in use since the 50s. Thepropylene glycol (PG) solutions were introduced in the early 70s. They were initially marketed as non-toxic. There was an industry uproar and court action forced the manufacturers of propylene-based antifreezes to relabel their products as low-toxicity. In my discussions with Dave Embaugh at Valvoline/Zerex, I asked questions about these two glycol coolants. There is a 20-25% price premium for the propylene-based coolants. With the price premium for PG, it is a given that all new vehicles come from the factory with the less expensive ethylene glycol-based antifreeze. In the aftermarket, the EG fluids have a market share of 95%; the PG fluids have the remaining 5%. Embaugh notes that the two types of coolants should not be mixed. PG maker Sierra Antifreeze’s web site recommends cooling system flush before switching to their product.
Q8: Okay, the Chrysler’s recommendation up to year 2002 says ethylene glycol. Isn’t that the traditional “green stuff” that has been around for years?
A8: Yes, just be sure to use a low-silicate antifreeze per ASTM D-4985/GM6038M and ASTM D-3306.
Q9: Why all of the fuss over low silicates?
A9: The good old green stuff is known as inorganic additive technology (IAT). The IAT coolants have been around for generations. They contain silicates that form a protective barrier on everything in the cooling system, even rubber hoses.
Silicates plate-out quickly on metal engine parts; thus the silicates in a coolant solution can drop to less than 20 percent of the starting level in less than 10,000 miles. Another problem with silicates is that, under certain conditions, they can drop out of the solution and form minute deposits.
If this occurs between the shaft and seal of your water pump, the resulting abrasion will eventually cause a leak. In a cooling system that turns off coolant flow to the heater core when the heater is not in use, silicates can form a gummy deposit that, over the course of a summer season, might clog the core tubes.
So why even use silicates? Because they’re really good at what they do, especially in iron block/aluminum head engines. That’s why some manufacturers still specify using coolants with silicate corrosion inhibitors.(2)
Q10: So I understand that the green stuff (an ethylene glycol, EG, IAT, silicate formula) antifreezes need more frequent servicing as they plate-out as they provide a protective barrier to corrosion. How about Chrysler’s recommendation for the ’03-’08 cooling systems of a hybrid organic additive technology (HOAT) that is good for 5years/100,000 miles? What is HOAT?
A10: While there are some minor variations, there are three basic types of coolant available today: inorganic additive technology (IAT– typically dyed green), organic additive technology (OAT – typically dyed orange), and hybrid organic additive technology (HOAT – typically dyed yellow). To some extent, each will work in any cooling system, but each has been developed to meet car manufacturers’ specific needs for warranty and/or maintenance intervals. Filling a vehicle that was designed for one type of coolant with another type can sometimes cause problems, and if you mix-and-match coolants the same corrosion protection as the initial factory fill shouldn’t be expected.(2)
To understand Chrysler’s recommendation of hybrid organic additive technology (HOAT), one must first understand the silicate-free OAT antifreeze. The newer OAT coolants work differently than the older silicate, ethylene glycol, IAT coolants (the green stuff). Aluminum and ferrous metals form a surface-layer of corrosion in the presence of moisture, even the little bit of moisture in the air. OAT coolants anneal this metal-oxide layer into a thin surface coating that protects against further corrosion. Inherent with their design, the OAT coolants last longer than the old green-stuff IAT coolants. Regardless, with either type of inhibitor, there must be enough in the coolant solution to occasionally re-establish the barrier as needed.
It took almost 20 years of OAT development to make a coolant that would effectively protect against corrosion without using silicates at all.
As a bridge between OAT and IAT there are the hybrid coolants (HOAT) that use both silicate and organic acid corrosion inhibitors. HOAT type coolants are the factory fill for many OEM vehicles.2 Your ’03-’08 Turbo Diesel uses HOAT.
Q11: How much of the coolant is actually additives?
A11: With all of the discussion about IAT, OAT and HOAT, you’ll be surprised to know that the corrosion protection percentage of the mixture (matters not if it is EG or PG) is usually less than 4%, meaning the true “antifreeze” or glycol portion is 96%.
Q12: Is there a one-size-fits all coolant?
A12: To quote Dr. Paul Fritz, senior coolants technologist for ChevronTexaco Products Co., “Nothing bad will happen” when two brand-name coolants with different corrosion inhibitor technologies are mixed. By this he means that no sludge will form, there will be no damaging chemical reactions and the coolant will still carry heat
and protect against freezing.
However, when adding an IAT to an OAT system, the recommended coolant change interval will degrade to that of the shorter-life coolant. Typically, when the mixture stays below 25 percent new coolant on top of 75 percent of the original coolant, the corrosion protection performance will remain that of the original coolant. But as the mix of coolant technologies deepens—that is, if a cooling system has a slow leak and it’s continually topped off with a type of coolant that’s different from what is already in there—eventually the original corrosion inhibitor will be replaced by the new corrosion inhibitor. This will determine the resulting mixture’s overall performance. If someone continues to top off a five-year coolant with a two-year coolant, the resulting coolant mixture should now be changed every two years.
But you should not mix-and-match. According to Dr. David Turcotte of Valvoline Co., cooling systems are mechanically designed to work with specific types of coolant.
Filling a system with the wrong coolant could cause problems. In a 300-hour test of OAT coolant in a Ford engine designed for HOAT coolant, the water pump impellor and backing plate were seriously damaged by cavitation corrosion.
Turcotte and Fritz both said that it’s not possible to have one product that meets the coolant requirements of all the different automakers. Because some OEMs require silicate-free coolant and others mandate the presence of silicate, “one size does not fit all.”2
Q13: What coolant should I use?
A13: Looks like we’ve done a complete 360° walk around the block (cylinder block, that is). Please see the reprinted table that Andy Redmond provided in Issue 54. The short answer: Chrysler specification MSS-9769, HOAT coolant which is backward compatible to all years of the Turbo Diesel. That’s right, use the yellow stuff after you drain the green stuff. And, thankfully we do not have to be concerned with cavitation erosion.
Turbo Diesel Register - 1150 Samples Industrial Drive - Cumming, GA 30041 - www.turbodieselregister.com
Old 01-11-2011 | 01:55 PM
nofatum's Avatar
For the chart the above referenced, you have to go to:
http://www.turbodieselregister.com/t...ntifreeze.html
Old 01-11-2011 | 02:54 PM
Bob 1's Avatar
Thanks i think
I`m worn out just reading the answer.
Old 01-11-2011 | 03:38 PM
tryNto's Avatar
Approved coolants.
Originally Posted by Dr.Dizzle
they need a HOAT type coolant.
The third generation Dodge Ram specs. a (Glysantin) G-05 HOAT coolant. At the present time, there are four G0-5 HOAT coolants available. All of which are suitable for use in the Dodge Ram CTD. The following list contains those coolants:
Mopar 5 Year/100,000 Mile with (HOAT) Embittered
Ford / Motorcraft Premium Gold Engine Coolant - Ford Part #VC-7A
Mercedes Benz Antifreeze Agent - Part # Q 103 0002
Valvoline Zerex G-05 Hoat - Available in concentrate. The NAPA part # is ZXG051. NAPA carries all of the Valvoline product line. If they do not have it on the shelves or behind the counter, a store associate can order it for you.
Old 01-11-2011 | 04:02 PM
Dr.Dizzle's Avatar
Bob 1
Your Dodge Ram is factory filled with a (Glysantin) G-05 HOAT coolant. The following information is noted in the Dodge Ram Service Manual: " CAUTION: Mopar Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Mixing of coolants other than specified (non-HOAT or other HOAT), may result in engine damage that may not be covered under the new vehicle warranty, and decreased corrosion protection".
At the present time, a few G0-5 HOAT coolants are available. All of which are suitable for use in the Dodge Ram CTD. The following list contains the coolants which are readily available in concentrate:
1). Mopar 5 Year/100,000 Mile with (HOAT) Embittered: This is available at your local Dodge dealer; however, the price ranges between 26 and 34 dollars per gallon. It is dyed pink or can be red/orange in color.
2). Ford / Motorcraft Premium Gold Engine Coolant - Ford Part #VC-7A: This is available at Ford dealers. I have purchased this coolant on sale for 12 dollars per gallon.
3). Valvoline Zerex G-05 Hoat - Available in concentrate. The NAPA part # is ZXG051. NAPA carries all of the Valvoline product line. If they do not have it on the shelves or behind the counter, a store associate can order it for you.
Old 01-11-2011 | 04:04 PM
Dr.Dizzle's Avatar
Smile
Originally Posted by tryNto
Approved coolants.
tryNto,
Thanks! Beat me to it.
Old 01-11-2011 | 06:42 PM
Jeff in TD's Avatar
On Zerex's web page they say their G-05 Hoat is used by Dodge, died pink, as the factory fill.
Be sure to use distilled water, and replace it every 5 years.
Old 01-12-2011 | 08:18 AM
Bob 1's Avatar
Wait
I need to mix antifreeze with water? Just for the overflow tank?
Old 01-12-2011 | 09:46 AM
Jeff in TD's Avatar
If it just needs a little, I wouldn't worry about mixing. If it needs quite a bit I'd put in 50/50 or slightly better mix.
Old 01-12-2011 | 10:31 AM
tryNto's Avatar
When adding to the reservoir, Its recommended to always add 100% Anti-Freeze.
Old 01-12-2011 | 10:50 AM
Bob 1's Avatar
ok
thanks
Old 01-12-2011 | 01:44 PM
Shorts's Avatar
Yup, great info above. I needed to top off the reservoir as my little bypass hose on the side of the block has been leaking with this cold weather. This morning I picked up some of the Valvoline Zerex G05 coolant at Napa for $14 and change.
What qualifies as a little and quite a bit? I know that's hard to judge but let's say a quarter down on te full line? Half down?
Old 01-12-2011 | 02:19 PM
Bob 1's Avatar
Ya dumb question but
All summer the bottle was half full and now it`s empty.
Did the water condense as it got to colder weather and draw it all into the radiator?
i don`t think i have a leak in my bottle.
Quick Reply: Antifreeze
