Another Valve Adjustment Question
I just bought an 03 Quad Cab with the SO ISB 250 and 125,000 miles. When at idle I hear what sounds like valve clatter so I tried doing the valve lash adjustment last night and ran into a problem. I can't figure out how to get the crank at TDC.
I unscrewed a cover from the front of the injection pump and could see the gear but no marks. Are there any other ways ?
You don't need to look at the gears. I rotate the engine using the alt nut and just bring it around until the "line on the damper" is straight up at 12:00.
do half the valves, rotate on complete rev and adjust the other half. I don't have my notes with me to tell you which ones are adjusted together, but you could probably search on here and find it.
good luck.
good luck.
When adjusting the valves.use the following procedure.
1: rotate engine 'till #6 valves "rock"(Exh. closes,& Int. opens.)Adjust cyl.#1.
2:Rotate eng 'till #2 cyl. rocks.Adjust Cyl.#5
3:Rotate engine 'till ##4 cyl.Rocks,Adjust cyl.#3
4:Rotate engine 'till Cyl.#1 rocks.Adjust cyl.#6
5:Rotate engine 'till #5 cyl. rocks.Adjust cyl.#2
6: rotate engine 'till cyl#3 rocks.Adjust cyl.#4
Done.
Done.
Fishbait
11-23-2009 11:21 AM
Jezzhuntin
08-25-2006 02:51 PM
