Another block heater question
My 06 have a heater block that heats up the coolant that is the one that get plug in. When you turn the key there is a heater on the air intake and the oil filter. They come On @ 32 degree.
Ok I am puzzeld,
I will plug in my truck at nite and in the morning at about 38 outside the temp needle is up a little but the wait to start light still comes on? I check to make sure I have power to the heater itself by unpluging it at the block heater and testing for current. I have heard that when your block heater is working your wait to start light will not come on.. any ideas thanks. also has anyone ever had to replace their block heater?
Scott
Scott
Scott, you asked about whether "anyone ever had to replace their block heater?" Yes,..... I have had to put two (2) of them in my 1996 Dodge CTD 12 valve since I bought it new.
John_P
Thanks.. ok checked my temp this morning yes it is warming up faster so it must be working...it was 17 degrees and I had heat after 5 minutes of idle time. Thanks to everyone jumping on here and helping me out.
Scott
Scott
I just put on in my '05 at about 96,000 miles. I'll snap a picture of the bad one some time soon, and then post it.
Ok I am puzzeld,
Scott
Scott
On my 1996 Dodge CTD 12 valve truck, when I plug the heater in to my extension cord in the garage, after about ten (10) seconds, I can hear the heater start up. It makes a real light hissing type noise. This may not be the case on the CR Trucks though. Hope this helps you some.
John_P
Ok I am puzzeld,
Scott
Scott
I live in a similar climate temp wise right now. When my trucks not plugged in, 38 degrees out I get the light on when I turn the key on in the morning. If the truck is plugged in, the wait to start light does not come on.
Low Tech & High Tech Test
One of the easiest ways to tell your block heater is working is wait a few seconds and listen after plugging it in. You'll hear a sizzle after about 5 seconds. Of course it has to be a quiet environment to hear it. Mine makes that noise, as did other vehicles I owned with block heaters. The other way to test it is just use an ohm meter and measure the resistance at the two prongs of the plug. If resistance is negligable, you're good.
Also, I should add that I would expect that a block heater isn't enough to bring the entire engine up to a temperature where the glow plugs don't go on, which is what I assume the yellow "coil" light is. Typically the engine block heater looks like an oven element about the length of your thumb since the orfaces in the block that flow coolant are not huge.
with my 06 being plugged in in a non heated shop at 15*F (-10*C) the intake heater wont come on before i start the truck, it will start to cycle on and off immediatly after startup but not before. the entire head on my truck is warm before i start it, the hoses and the rad are cold but the engine sure aint
It is amazing, considering the size of a block heater, that such a small thing can generate this kind of heat. But then again, if sizzles in just a few seconds at even -40 deg C (like it was here a couple of weeks back) I can believe what you are saying. I suppose I should "lay hands" on my engine and check!
On these trucks there is the yellow coil light which is the glow plugs then there is of course the intake manifold grid air heater. The glow plugs only ever cycle once at cold enough temps on key ignition just for starting purposes. But the intake manifold grid heater cycles whenever required: I've been at a stop light or drive-through in severly cold weather and the engine temperature starts to drop...when this happens, the grid heater cycles a few times...but never when driving.
Are there any other heating functions?
as weird as it sounds there is no glow plugs in these trucks just the intake heater. the little yellow coil light that comes on prior to start up is just warning you not to start it cuz the intake heater aint done runnin yet, and ya it will come back on after the temp starts droppin as long as the temp is low enuf and the speed is below 20 MPH
rjm022
12-11-2019 09:17 PM
supersonictoys
11-08-2008 09:17 PM
EClancy
10-25-2005 04:20 PM
