Another APPS thread...'03 HO
Old 06-26-2009 | 08:41 AM
Grit Dog's Avatar
Looking for a little guidance here.
A buddy's '03 6sp HO truck started having the dead/intermittent throttle issue. Appears to be the APPS going out. Got codes 2121, 2122, and 0633.
1st 2 are definately APPS related.
Tried to reset a couple tiemes without success, cleared codes, etc.
Pulled the plug off the bottom and cleaned the contacts on it. Cleared codes and did the reset again and it worked...for one run thru the gears and then threw the codes again, dead pedal, etc. SHut the truck off for a little bit, then when he took off, it worked fine all the way home.
Seems to me, the APPS, bell crank sensor, whatever you call it is just slowly giving up. If it was out of adjustment, it would be a more constant problem I think.
Who thinks the APPS is just bad?
Old 06-26-2009 | 06:25 PM
MikeyB's Avatar
Seems like you went though all the motions with the APPS.
Contact Timbo01 on this site for one of his aftermarket APPS modules. Cheaper than the dealer and better quality.
MikeyB
Old 06-29-2009 | 07:55 AM
Grit Dog's Avatar
Thanks for the info Mikeyb.
Old 06-29-2009 | 01:36 PM
RowJ's Avatar
Can reach Tim HERE
Great way to go....and saves lots of money!
Had mine for 4 months....got no APPS codes but all indicators pointed in that direction. Tims sensor solved all my problems!
RJ
riddle family
01-23-2010 12:40 PM
schoust
10-21-2009 10:09 AM
the496rocket
12-17-2008 10:42 AM
Jezzhuntin
08-25-2006 02:51 PM
in2gpn
03-27-2006 11:16 PM
Quick Reply: Another APPS thread...'03 HO
