Annoying tic under the hood? I found mine... EASY fix.
Old 12-09-2009 | 09:55 PM
  #31
madhat's Avatar
Administrator/Jarhead
Hm.... interesting.... I see your point.
Old 12-12-2009 | 10:05 AM
  #32
1Happycamper's Avatar
Hi Guys. Checked mine the other day and they were loose. Tightened them down and the tap-tap seems louder. How tight is tight. Thanks.
Old 12-13-2009 | 03:40 PM
  #33
DirtEater's Avatar
Got around to pooping the hood and sure enough, mine was ticking too and the small screw was loose. Got noticeably quiter after tightening. Thank for the heads up, madhat. You da man.
Old 12-13-2009 | 03:45 PM
  #34
madhat's Avatar
I TTY... (torque to yield), fairly tight, but not straining. Heck, if it made it louder, then take them off...
Originally Posted by DirtEater
Got around to pooping the hood and sure enough, mine was ticking to and the small screw was loose. Got noticeably quiter after tightening. Thank for the heads up, madhat. You da man.
You pooped the hood?
Nope, just tryin to be like you.
Old 12-13-2009 | 03:57 PM
  #35
megacabdad's Avatar
That stinks.
Old 12-13-2009 | 04:01 PM
  #36
DirtEater's Avatar
Oh man, I'm LMAO. How did I get that one wrong?
Old 12-13-2009 | 04:27 PM
  #37
NickBeek's Avatar
The number one line doesn't have a hold down on it. On older trucks number 6 doesn't either.........
Old 12-13-2009 | 04:37 PM
  #38
DirtEater's Avatar
That's what I noticed too. Only 5 of them blue isolator thingies. I'm just puzzled as to why it's the #4 that comes loose. I checked all the others and they were fine, but #4 was way loose.
Old 12-14-2009 | 05:08 AM
  #39
bigblkgun's Avatar
Annoying TIC!!!
Ok I tightened mine and the last four were loose. If this works I will be so happy! It has been driving me nuts for over a year!!! Hopefully it'll have an effect on the (what sounds like valves but isn't) clatter when I accelerate!!!
Old 12-14-2009 | 08:34 AM
  #40
Lost Lake's Avatar
Are these insulators or isolators?
Old 12-14-2009 | 02:49 PM
  #41
DirtEater's Avatar
They're an isolator and also serve to strengthen the line as a stabilizer.
Old 12-14-2009 | 06:23 PM
  #42
1985cucv's Avatar
i did mine and they are quieter thanks madhat!
Old 12-14-2009 | 06:40 PM
  #43
madhat's Avatar
I'm glad I helped at least one person on this website, as much as I get from it!
Old 12-14-2009 | 07:28 PM
  #44
1985cucv's Avatar
yeah i had a wierd tic and i was like i need to check this out when you first posted it well last nigh i checked it out and the number 3 and 5 were loose enough now now more noise well kinda its a cummins
Old 12-15-2009 | 05:11 PM
  #45
ripping r's Avatar
checked mine today. and they were not realy loose. but i gave them a little more and.....wow no more tic...tic...tic..
Quick Reply: Annoying tic under the hood? I found mine... EASY fix.
