amsoil bypass oil filter system
Old 05-21-2021 | 11:44 PM
michaelaland's Avatar
Hey folks,
Made a mistake in doing my oil lchange and after draining engine oil, filled up regular filkter with oil before putting back on and then filled up amsoil bypass filter with used oil by mistake. Probably about a quart or little more. You think that is a big deal since the other 12 quarts or so are all new?
Old 05-22-2021 | 09:57 AM
FMB's Avatar
FMB
I certainly wouldn't sweat it. If it bothers you too much, you can change the oil and filters a few hundred miles earlier.
Back to morning brew . . .
Old 05-22-2021 | 11:01 AM
Thanks FMB, I didnt think it was a big deal either I just couldnt believe how only one quart to 12 changed the color of the oil so much, but also I have never had the amsoil bypass system and just wasnt quite sure if I may have clogged up its filtration system by putting dirty oil into the filter and prevented it from filtering out the smallest(1 micron) particulates...anyway, thanks again for your reply.
justen920
10-02-2012 08:15 AM
jonesm8
33
03-07-2007 07:21 AM
jmccart
01-22-2007 09:52 AM
ftltmp
01-10-2007 08:10 AM
WEATHERBY460
44
07-30-2006 01:15 PM
Quick Reply: amsoil bypass oil filter system
