Am I changing my Oil to often?
Old 11-19-2007 | 09:19 AM
  #31
b.lee's Avatar
i change my oil when I'm bored, whenever it looks dirty/black.
cheap insurance, don't care who you are, and or what you say.
cleaner oil = better oil = longer engine life = .
Old 11-19-2007 | 09:33 AM
  #32
Roperteacher's Avatar
B.lee If you had a 3rd g en truck, you'd be changing your oil every other day or so to keep your oil from turning black!!
Old 11-19-2007 | 09:53 AM
  #33
Raspy's Avatar
Fortunately my truck is an '04 and doesn't instantly blacken the oil. But even if it does, that is not an indication that the oil is bad. Cummins says 7500 to 15000 and the oil in the newer trucks is black way before that.
I change mine at 10,000 mile intervals using Delo 400. It has 120,000 on it now and I've never had to add a quart between changes. Real easy to keep track of to.
John
Old 11-19-2007 | 10:58 AM
  #34
Springer's Avatar
Originally Posted by DiEseLjunKy
FYI they changed the recommendation on fuel filters last year and say to do it every 10,000 miles with a 7 micron or better rated filter.
When did the change the fuel to 10k ? My owners manual says 15k
Old 11-19-2007 | 06:40 PM
  #35
redeyedracer's Avatar
I change my between 8-12k (heavy towing) using dello, blackstone test always come back good (they say "run it longer!!!").
I would consider running synthetic OR less than 8k an oil change a WASTE!!!
I also change my fuel filter with every oil change...cause all it takes is one bad tank of fuel!!!
Old 11-19-2007 | 09:30 PM
  #36
Rednecktastic's Avatar
Changed it twice so far at around 7500 miles. Changed the fuel filter at 15K.
Thinking of doing fuel filter and oil at 10K from here on out.
http://www.everytime.cummins.com/eve...aintenance.jsp
http://www.everytime.cummins.com/eve...ions/ram59.jsp
I think the reason they reduce the intervals on the cg is because you have to run ULSD to use it. But that is already available. I think this has been discused before.
Old 11-20-2007 | 04:43 AM
  #37
MOJO1's Avatar
I change mine at 10k I do run AMSOIL 5-40 and a AMSOIL 2QT,bypass as well oil looks and smells cleaner Oil samples test says im good for alot longer my have to check in to doing this or not
Old 11-20-2007 | 09:42 AM
  #38
Amsoil synthetic 15-40 says you can go 25K miles. I think I might do this next time and change it at 20K.
Old 11-20-2007 | 10:13 AM
  #39
JD Dearden's Avatar
I change mine every 3k and it is very dirty
Old 11-20-2007 | 10:25 AM
  #40
Outwest's Avatar
5,000 mile intervals with Delo. 90% of these miles towing. I think synthetic oils can give better performance in extreme conditions but I don't think we should extend oil change intervals with stock oil filtration. Especially with the new 6.7's.
Old 11-20-2007 | 11:13 AM
  #41
BLUEBURNER's Avatar
I change mine at 5k also
Old 11-20-2007 | 11:15 AM
  #42
dezeldog's Avatar
I change mine at 15k with 2 filter changes....at 5k and 10k then have it analyzed. The report always says "all elements are acceptable....change and resample at normal interval". This has worked for me for over 500k on 2 trucks.
JIm
sakisaki400
56
05-31-2007 11:12 PM
1stTimeAround
26
07-10-2006 11:56 AM
Geico266
02-23-2005 02:11 AM
OH Sick
12-17-2002 04:42 PM
TXTad
14
10-23-2002 03:06 PM
Quick Reply: Am I changing my Oil to often?
