Am I changing my Oil to often?
Old 11-17-2007 | 03:13 AM
CUM4X4MINS's Avatar
Do you guys think I am changing my oil too often at 5K? Don't tow real consecutively and not a lot of stop and go. Thanks for the imput.
Michael
Old 11-17-2007 | 04:37 AM
Swayse's Avatar
I change my oil at 5,000 miles too. Oil is black as paint after 5,000 miles.
Old 11-17-2007 | 05:14 AM
eddiebob's Avatar
I change mine at 5,000 miles with a bypass oil filter. Ed B
Old 11-17-2007 | 05:52 AM
coolslice's Avatar
I change mine every 3500-4000. I don't see what could be bad about it. I think it beats doing IOA's and running crazy bypass filters.
Old 11-17-2007 | 06:23 AM
DBM's Avatar
DBM
i change mine at 7500 with royal purple synthetic.
Old 11-17-2007 | 07:05 AM
MikeyB's Avatar
Change mine every 7k with the CJ rated oil.
Probably do a OA at 5k with the new CI oil and see how it's holding up and determine if I should go to 7k.
MikeyB
Old 11-17-2007 | 07:13 AM
m.rehme's Avatar
I use Mobil 1 and change every 25,000-- 321,000 miles and still going strong.
Old 11-17-2007 | 07:56 AM
jrussell's Avatar
It's also black after 5 seconds of driving.
Old 11-17-2007 | 08:06 AM
surfram's Avatar
I change my oil every 7,500 miles with Rotella synthetic 5-40.
Old 11-17-2007 | 08:24 AM
t-boe's Avatar
First 3 oil changes were every 3,000 for me. Now I'm going every 5,000. Probably completely unneccesary, but it gave me a warm fuzzy...
Old 11-17-2007 | 08:26 AM
donhov's Avatar
The oil on all the newer 5.9's is black as fast as you pour it into the engine. As far as the change schedule do what you want, but Cummins recomends 7500 miles between changes for heavy duty and 15000 miles for light duty. I have read that the new 6.7's with the new oil require more frequent changes but think that 5000 miles changes are quite a bit too frequent. JM02.
Slow down our oil dependecy, change as recomended or as oil analysis sugests..
Old 11-17-2007 | 08:40 AM
Casey Balvert's Avatar
Every 7500 miles or once a year, whatever comes first. Rotella T.
Old 11-17-2007 | 09:10 AM
STate's Avatar
Every 7500 like the book says, Shell Rotella SAE 15w40
Old 11-17-2007 | 09:22 AM
djbikeman's Avatar
I agree 100%. The only valid reason to change your oil at a lower mileage interval (below 7500 miles) is that you don't drive enough miles to change your oil twice a year or that an OA recommends it based on your driving conditions. "Cheap insurance" is not a valid reason, it's a waste.
If you feel the need to go above and beyond recommended service intervals, change your fuel filter more frequently. The 3rd gen forums are full of fuel and fuel system related problems, but nobody is complaining about oil/lubrication issues.
Old 11-17-2007 | 09:56 AM
Ronby's Avatar
7500 miles on oil change and 15000 on fuel filter just as recomended is what I do on my 04
Quick Reply: Am I changing my Oil to often?
