Airing/Balancing DRW
I have an 05 dually and it is a pain in the _$$ to change the tire pressure with the stock valves. I am thinking about putting in extension valves but do not want to throw off the tire balance. Just wondering if I should go to balancing beads instead of weights on the tires. Anybody else been through this before me?-your comments would be much appreciated.
I didn't change anything on the truck but I did buy a tire pressure gauge with a dual head and a dual head chuck for my air compressor. I still have to locate and feel around for the stems on the duals but it's no long a problem to check or adjust air pressure.
Here is your answer, it's not cheap, but they sure are nice! And very easy to change tire pressure! They are a real quality product!
Tire-Man
Forget about the Master ZIP™ Airless Valve Extenders and Air MasterTM Dual Tire Inflators! I tried them and they don't work right, more trouble than you care to experience!
Tire-Man valve stems are the way to go!
Tire-Man
Ditto, I did the same as Lee S and have no problems.
lawdog800
19
03-31-2011 09:26 AM
89dieselkong
04-05-2009 05:20 PM
jlipskoc
03-07-2009 08:00 PM
