Air Bag Light - Please Help!
Old 06-02-2011 | 10:31 AM
justagoodolboy's Avatar
I took my dash out to install a new radio, and got a little carried away removing the console, glove box and anything else that would easily come out for cleaning purposes. Upon reinstalling everything, by ABS light is now on, and I've tried everything to get it off minus taking it to the dealership. To date, here is what I've done:
- checked the wires to the dash switch to make sure they were not torn, stripped or disconnected, and tried a new switch with the same results.
- unhooked the battery and let the truck set for about 10 minutes hoping the computer would reset everything, which it didn't.
- hooked by dads snap-on scanner up to it, and received no codes.
Any ideas?
Old 06-02-2011 | 10:36 AM
cbrahs's Avatar
takes longer than 10 minutes for the ECM to discharge the capacitors UNLESS you remove all battery connections (both positive and negative on both batteries) and step on the brake pedal a few times. this discharges the capacitors in the ECM to give the reset. try that first. as for codes, a generic scanner (even though its a snap on) will not dig into the ABS module unless that scanner has the capabilities and that aint cheap.
Old 06-02-2011 | 10:49 PM
OOPS's Avatar
Your title says "Air Bag Light" while in your post you ask about the "ABS". Two different systems, one is brakes (ABS) the other is the Air Bag, which one is it?
Old 06-03-2011 | 08:51 AM
Good catch - I got in a hurry. Its the air bag light. Sorry!
Old 06-03-2011 | 09:19 AM
sr4440's Avatar
are you sure you got the wiring hooked back up under the air bag control module trim cover? that's the cover under the ash tray.
Joe
Old 06-03-2011 | 11:44 AM
I didn't see anything under my ash tray, my console that has the 4x4 shifter and 6 spd boot goes up under the ask tray. Guess I should take a closer look in that area.
Old 06-03-2011 | 11:48 AM
Nascarcamper's Avatar
I see single cab in your truck description, check wiring to passenger bag dis-able switch.
Lonepine78
09-25-2013 10:57 AM
jtandgwen
03-13-2011 08:11 PM
PZM123
02-05-2007 06:01 PM
MasseyMan1089
09-12-2005 06:49 PM
aceheater
02-21-2005 05:40 PM
Quick Reply: Air Bag Light - Please Help!
