Advantages of 6 speed stick...
Are there any significant advantages to a stick shift?
Also, anyone here ever replace a clutch?
If so, how long did the first one last?
How much did that set you back?
Now I'm thinking I may buy a stick.
Thanks!
DT.
Thanks!
DT.
Nothing like "rowing the boat" for me. I have always hated slushboxes. I have never replaced a clutch, but there are several people on this board that are running aftermarket clutches. I have found the stocker to be adequate for an un-bombed truck. South Bend is a popular aftermarket clutch. The 48re is a relatively new auto so there are not a lot of high mileage units out there, but the previous 47re is well known as a transmission that does not stand up the the high torque of even a stock Cummins, especially if used for heavy towing. I have had several Dodge/Cummins combos in both auto and stick configurations, and out of eight trucks, I have never had a stick that had trans or clutch problems, and I have only had one auto that DID NOT have transmission problems. (All of my auto's have been 47re's)
Another thing with the 6 spd is that you have some imput of where the RPM is and also some manual control for slowing down. Oh yeah did I mention E Brake??
Automatics are fer little 'ol ladies.....
Yes.
I've never had a 6 speed.
That's alot of gears. Must be to provide the driver with finer control across the entire powerband of the Cummins.
Even the 48RE, has alot of gears for an auto.
When I started lookign at the Ram Cummins I figured I'd buy a 3500 short bed quad cab with the 48RE.
Now I'm leaning toward a 3500 long bed quad cab 6 speed.
The debate going on in my head has been mostly settled by reading this board.
One thing's for sure:
The wife won't be driving it if it's a stick, and that may be a good thing!
Originally posted by dieselnewbie
Yes.
Yes.
48RE only has 4 gears.
My wifey drives the truck - - not much, but she does it. She prefers her Town Car - - now try and figure that out.
You get to stay at an RPM that you want for the conditions.
Easy to add an e-brake.
If you stay stock power you probably won't ever replace your clutch. unless you keep your truck for a realy long time.
steve
steve
Well here is my two cents...I have been driving my 04.5 3500 dually for oh, two days now...sort of makes me an expert huh? I run 4.10 gears and find that 6 speeds, like the others say, is superfluous when running empty. I just get to fifth ASAP and leave it there until I have to stop...Sixth is an OD and used when I hit the highway...Rob in Maine
OK, here's a modifier:
What if most of the time you were just using the truck as your daily driver, and not towing or hauling anything?
And when you did tow or haul a payload it never exceeded the capacity of the 48RE tranny.
What transmission would you prefer for level of use?
Thanks,
DT.
Thanks,
DT.
I guess I'm the odd duck, in that I generally hit all 6 gears even when empty, and I wish it either had more gears, or a bigger jump between ratios.
There seems to be a smaller RPM jump between the higher gears, and I would gladly trade a bigger jump to have both the trailer towing ability of a truck with 4.10's (in low) and the ability to keep up with traffic in a 75 zone without winding out the engine, like a truck with 3.73's in 6th...
Auxiliary transmission with splitter, anyone?
i have a 6 shooter and love it. i usually start in 2nd and hit em all. i use it as a daily driver, and for anything that i might want to pull. i wouldnt trade it for a slush box. but that just my .02
Love my 6 spd... start in 2nd(unless I California stop it then I go from 3rd) and I hit all the gears. It's my only vehicle so I drive it everywhere... in town, highway, empty or loaded... it could definitely use a few more gears though...
I have a 5 spd, and there was never a question about stick vs auto. Funny though, one would think everything else being equal the that a 6 spd would be used on the SO while a 5 spd would be used on the HO, as more gears are needed for heavier loads and lower engine output. I know that the 6 spd that is used is heavier duty, but one would think.....:^)
I might sound like a stick in the mud - but because of long term syncro. the manufacturer recomends shifting in chronologicle order. That said, I iove my 6-speed and wish we had at least 1 more tall gear. Starting off in 2nd and going through to 5th does'nt take you far. ( 5th is good from 30mph to 65mph w/3:73) Of course that is empty. Hauling loads this system is a blessing! I still have not been touched on the big hills, and I'm running a stock 305/555 2003. YEH!
