Adding an Exhaust Brake
Old 03-06-2008, 02:35 PM
SundayMoney's Avatar
Here is where I put my switch.
I also run mine all the time. It makes my truck warm up about 50% faster. The install was pretty easy. It took about 3 hours with a few beer breaks. Its basically a bolt on install,other than drilling a couple holes for the air tank.
The instructions were well thought out. I highly recommend the Pacbrake PBXR.
Old 03-06-2008, 02:53 PM
bansh-eman's Avatar
how aggressive is it when you let off the gas? i guess my concern is that everytime i let off the gas i dont want the thing to think i need the brake applied. so times i just let off and let it coast becasue i know the cars in front of me are playing accordian
Old 03-06-2008, 03:06 PM
If thats the case,turn it off.
Old 03-06-2008, 03:21 PM
bansh-eman's Avatar
and its safe to flip it on at any point while driving correct? no issues with shorting any of the componants?
Old 03-06-2008, 03:30 PM
No harm done.
Old 03-06-2008, 03:35 PM
bansh-eman's Avatar
kool, thank you guys for taking the time to explain this to me
Old 03-06-2008, 03:38 PM
I forgot to add,the Pacbrake comes with an accessory kit so you can use the Pacbrake compressor to air up tires,*****,etc. It comes with a hose about 25' long. Long enough that I can air up the rear tires if needed.
Old 03-06-2008, 03:42 PM
bansh-eman's Avatar
ahh that would be nice to have in the desert!!! let the air out of the tires so i can make it through the dunes then air them babies back up when i get to the road!!!
what kind of pressure does it make?
Old 03-06-2008, 04:04 PM
It doesn't make a ton of pressure and doesn't have much volume,so I don't know that I'd try and air up 4 tires unless I HAD to.
But for airing up before towing (adding 10-15psi) it works fine.
Old 03-06-2008, 04:05 PM
ptgarcia's Avatar
150 p.s.i., but low volume. Pacbrake has upgrade kits with larger compressors and larger tanks.
There's a big Dodge gathering in Glamis this weekend. If you're not busy come on out. PM me if you'd like more info.
Old 03-06-2008, 04:07 PM
bansh-eman's Avatar
i'd love to but i got to save money for my trip to Dumont to ride my quad that broke the first trip out to glaims after rebuilding it lol
Old 03-06-2008, 10:00 PM
troll3193's Avatar
There is a fine point you will find where you have enough pressure on the pedal to have the brake not engage, but are also not accelerating..
You get used to it. I have not turned my brake off since I got it, except for a couple of situations where the truck was colc, but I did not want the extra noise of the brake engaged...
I love driving with it, because if you time the turns and stuff right, you hardly ever us your service brakes... Also great when you need to slow down quick. Drop it to 2nd gear, the truck will downshift when ready and it really slows you down fast...
I highly recommend getting one...
Bryan
Old 03-06-2008, 11:45 PM
bansh-eman's Avatar
how much did you guys pay to have it installed? and troll do you have the pacbrake as well?
Old 03-06-2008, 11:50 PM
ptgarcia's Avatar
Paid $1040 shipped and I installed it myself.
Old 03-07-2008, 12:13 AM
bansh-eman's Avatar
i'm not too comfortable doing the install my self, this is the first time ive ever had or been around a diesel. the old lady would KILL ME if i messed it up lol
and i'm a TOTAL perfectionist, problem is I cnt perform perfection on stuff like that cause i dont kow what i'm doing
Quick Reply: Adding an Exhaust Brake
