AC Pressure Switch Question
Old 12-05-2010 | 10:35 PM
raiderred77077's Avatar
I posted this in the performance forum by accident and wanted to re post in the correct place. Sorry about that.
I have a 2007 Dodge 2500 w/ the 5.9L that is having AC issues. Yesterday the everything worked fine and today nothing. I turn it on and the clutch on the compressor is not engaging. I checked for leaks, and the system has 100 lbs on the high and low side w/ the compressor off obviously.
I checked the voltages on the terminal that plugs into the pressure switch and I am showing 5 volts when I have the AC button engaged and off. From reading an old post Madhat it looked like the pressure switch does operate b/t .451 to 4.519 volts. Here is the a partial quote from his post:
For the air conditioning system to operate,
an A/C pressure transducer voltage reading between
0.451 and 4.519 volts is required. Voltages outside
this range indicate a low or high refrigerant system
pressure condition to the Powertrain Control Module
(PCM) or Engine Control Module (ECM) depending
on engine application. The PCM/ECM is programmed
to respond to a low or high refrigerant system pressure
by suppressing operation of the compressor.
Refer to the A/C Pressure Transducer Voltage chart
for the possible conditions indicated by the transducer
voltage reading.
So how do I find this A?C Pressure Transducer Voltage Chart or a wiring diagram for the HVAC system on this pickup? Thanks for the help folks!
Old 12-05-2010 | 11:24 PM
jhenson's Avatar
Hmmmm....Madhat any input on this? I'm sure some others might be wondering the same thing. Thank goodness my '03 has had most of the a/c system replaced by yours truly and blowing extremely cold.....oh, wait, this thread was on how to just get the thing work .....Madhat...anyone???
hoot
03-14-2011 04:43 AM
Barryn
07-14-2008 09:30 AM
SPLnut
12-31-2007 11:27 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
redramnc
03-28-2005 06:58 AM
Quick Reply: AC Pressure Switch Question
