Is 911 bad on fuel system
Fuel gelled up last night & I had to use some 911. Is this stuff bad on the fuel system? Anything that I shoudl be doing now to compensate for it?
It is suppose to be used only to ungell a gelled up fuel system. You will be fine but don't regularly use it. You are a lot better off treating the fuel with antigel additives if your fuel has problems
So I guess that it's a necessary evil when your gelled up (like I was) & can't get the vehicle to where it is warm. Is there anything that I should do now that I used it?
If your worried then pour between 16 oz and up to 32oz of 2 cycle outboard ashless TCW-3 oil in to 30 gallons of fuel to help lube the fuel system. You can get it at Wallys for $8.xx a gallon or under $1.75 for a qt of it. I use 16 oz of 2 cycle oil and 10 oz of PS winter formula to every 30 gal of fuel.
RAKFIRE
06-01-2008 07:04 PM
Mark Hodowanec
02-05-2007 01:01 PM
