Is 85-140 Synthetic Blend okay?
Pauly,
That stuff will be just fine. No problems. Because it is a blend though, I would change it at the next scheduled interval. Nothing wrong with the quality of the oil, but just doesn't last as long as straight synthetic if you like to use extended drain intervals.
Cool.
Does Dodge call for full synthetic in the diffs? I'll use that if it's what is called for, otherwise I'll save a few bucks on the blend.
Thanks!
Save the money and feel good. It's just not that big a deal as long as you change it when you should.
FWIW-- I use the high dollar Schaeffer's stuff so it's not like I am just trying to talk you into doing what I do.
Because our trucks use a torsen style diff I would make sure you only use synthetic...Dodge also recommends full synthetic as well.
Copied from Dodge service manual:
REAR AXLE
² 9 1/4 - MoparT Synthetic Gear Lubricant 75W-140
² 10 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
² 10 1/2 AA EL- MoparT Synthetic Gear Lubricant 75W-90
² 11 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
² 248RBI - MoparT Gear & Axle Lubricant SAE 90
REAR AXLE
Get on Amsoil's website, get their 1 800 and call them. Become a perferred customer for $20 a year and order their products at a discount. You may be able to join and order on the same phone call. I just ordered 75/140 to put in the rear.
ratlratl
81
03-12-2010 09:04 PM
