6th gear?
Old 09-27-2006 | 09:35 PM
gus's 03's Avatar
fyi 03 6sp w/ stock tires is just a tick over 1900rpm @ 60mph, swaping 35" tires puts it @ the same rpm @ 70 mph....
Old 09-28-2006 | 12:55 PM
willmc's Avatar
Thanks but I really would rather have stock size tires on the truck. Anyone know what my rpm's will be at highway speeds with stock tires and 3.73 and the 6 speed?
Will
Old 09-28-2006 | 02:00 PM
Duallydog's Avatar
With the G-56 6spd they should be around 2200rpm at 70mph.
Old 09-28-2006 | 04:32 PM
willmc's Avatar
Wow, I was hoping it would be better than that. So the 3.73 gears will only be a few hundred rpm dif than the 4.10's? Well, I guess I'll still do it eventually if I find a donor.
Thanks,
Will
Old 09-28-2006 | 05:49 PM
bluepp's Avatar
Originally Posted by bigblock2stroke
3.54's/4.10's from 2nd gens were Dana
3.73's/4.10's on 3rd gens are American Axle Manufacturing.
Not interchangeable.
although the grapevine is active with thoughts of bringing it back to make up for lost fuel economy on the new emissions engines.
Thats what I meant , Put the whole Dana rear end in . Find a wreck that has 3.55 gears , change the whole thing.
Old 09-28-2006 | 09:08 PM
12PACK's Avatar
FWIW, the truck in my sig has the stock 265/70/17's and I'm turning 1,950 @ 65 mph in 6th. I have the 3.73's.
Old 09-28-2006 | 09:13 PM
Duallydog's Avatar
You also have a transmission that Dodge no longer puts in their trucks. The G-56 is just short of the NV with 4.10s
Old 09-29-2006 | 12:09 PM
willmc's Avatar
Thanks! That is what I need. Makes more sense to get the GV unit then. I can keep the low gears in the unlikely event that I need them and still turn lower rpms at highway speed in double OD.
Thanks again.
Old 09-29-2006 | 06:47 PM
12PACK's Avatar
[DeNiro voice] You talkin' to me? [/Deniro voice] If so, the reason I posted that was Will is looking at an 03, which has the NV like my ram. This will give him an apples to apples comparison.
No problem, Will.
Old 09-29-2006 | 09:41 PM
Duallydog's Avatar
Oh sorry. My bad.
Stealth Mode
11-20-2005 01:57 PM
Buckshotram
11-01-2005 11:28 PM
GCSS
05-12-2005 10:41 AM
Dieselcamper
03-17-2005 08:16 PM
More Power
01-25-2004 06:44 PM
Quick Reply: 6th gear?
