6lbs fuel pressure
6lbs fuel pressure
Here's the deal.
My gauge shows 6 lbs at idle and drops to 0 with moderate throttle. It has been doing this for a few months now. Is this normal for a lift pump going out ? I would not think it would last this long acting this way. BTW I have the filter mounted pump w/ 210,000 miles on it. I would assume bad pump, BUT how is it STILL GOING ??
One more thing... I don't have nearly the black smoke I used to with the quad on 100. Would this be why?
Are there any Cheap options ?? I know, know, don't go cheap, but I need to for now til I can afford better. I don't mind spending a lil now to make it til spring. Thanks
Last time my '03 did that was during a trip through Kansas this past summer. Parked and camped (5th wheel) at a closed shop, where I had them change the fuel filter the next morning. Nope, didn't have tools/filter with me.
Back up and running just great. Bad fuel! I'm hoping for you to have only the same issue.
Yes, Geno’s has the stock pump for a good price.
http://www.genosgarage.com/prodinfo....UMP_FPD4089602
I am amazed how long that pump has lasted you. I know of many that failed around 50k miles. My favorite aftermarket pump is the Walbro kit sold by Glacier, but there are many different kits to choose from.
I am hoping that the problem is just the filter. I'd love to be able to run this pump for another 50,000 miles just to say I did.
is there a cheaper pump we can mount in the frame rail and tie into existing fuel suction line? or would you have to remove old lp in tank first? i know theres raptor,airdog,glacier but what about any industrial/automotive type fuel pump as long as it puts out 10 psi roughly?
WOW. I changed the filter today. Now at idle is about 8lbs, but stays to at least 6 under moderate to heavy throttle and only sucks down to 2 lbs at sustained WOT.
Guess my STOCK fuel filter mounted lift pump will keep on kicken past the 210,000 mile mark. :-)
dodgeguy71
17
01-19-2012 12:52 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
